SUPPORT OUR SPONSOR
Old 04-02-2002, 12:43 PM
ronzara's Avatar
Cobra Make, Engine: Everett-Morrison 351w assembly STILL in progress
Send a message via AIM to ronzara Send a message via Yahoo to ronzara
Default Alternator Connection ???'s
I have solved my 351W alternator bracket problem by cutting off 2" of the mounting end of a 302 bracket. Then by redrilling a new hole, I was able to mount it to a lower water pump bolt. The top of the alt, I mounted with a 6" bolt and a spacer into the top/front Head mounting hole. A 30" V belt aligned the alt perfectly in the center of the adjuster bracket.
Now my question... The Motorcarft Alternator I have is an older style, with 4 poles on the back. They are labeled:
STR
BAT
GND
FLO
obviously... BAT = Battery, GND = Ground
What is STR and FLO
Where & how do these connect?
Is there any thing else I need in-line between the Alt poles and their destination?
Is there a harness made for this?
I know this sounds like a bunch of dumb questions,... but the electrical stuff isn't my forte!
And as they say the only dumb questions are the ones you don't ask! Thanks for your help!
Ron Zara
ronzara@hotmail.com
1. "Putting a Chevy Motor in a Shelby Cobra is like CUSSING IN CHURCH!"...... ME
2. "Friends Don't Let Friends Drive Junk"....
Old 04-02-2002, 12:56 PM
Ron you should try a search first...we just went thru this with me...LOL
I have a Ford STD PAW 60 amp chrome alt. with no markings on the terminals..just coloured isolating terminals.
Also have the 4 pin external voltage reg.
Thank the board for the multitude of information when a guy is in need.
Scroll down to the bottom to see if your alt. looks like Bob Putnams pic. Good diagrams form Bob.
alternators and regulators
Hope this helps
Tim
Old 04-02-2002, 05:13 PM
427sharpe's Avatar
Cobra Make, Engine: A CSX Cobra,1966 GT350 and an '06 Ford Heritage GT
Post
It's not 'FLO' but FLD= Field. STA= Stator. In the 60's, which has the easiest wiring I think, the Stator wire on the Alr feeds back to the S post on the voltage regulator. The FLD post feeds to the F post on the voltage regulator. Yes, BAT is the hot lead to the battery and GND is ground.
"I think we have more machinery of government than is necessary, too many parasites living on the labor of the industrious." Thomas Jefferson
HTML code is On
