SUPPORT OUR SPONSOR
November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 05-16-2002, 10:24 AM
Cobra Make, Engine: SPF - 427 Stroker
Question Oil Thirsty 427 - Need Side Oiler ??
I am in the process of discussing a full engine build with Coast High Performance. I want a 351 W stroked to 427 and will be using it initally for once a month track use only. I will however be using it on the street eventually and would like something that is a good combination of both that will last and is very durable.
The engine builder is telling me I am going to need a side oiler or electric oiling system for the track. Is this true ?
I am not going to be racing it, but will for sure be driving it hard with the rev limiter set to 62-6500 and the builder says it will go to 7000 no problem.
Any thoughts ??
Old 05-16-2002, 12:37 PM
Back in Black's Avatar
Cobra Make, Engine: West Coast. 514 / 6 speed Richmond overdrive
Question I don't have any personal info, but..
I would recommend that you do a search for Coast High Performance here at the club, see what others have to say.
About the oiling system, I know nothing, I see nothing!
James Madison, father of the Constitution, said, "If Tyranny and Oppression come to this land, it will be in the guise of fighting a foreign enemy." He also said, "No nation could preserve its freedom in the midst of continual warfare..."
http://www.standdown.net/index.htm
Old 05-16-2002, 02:32 PM
dscott's Avatar
Cobra Make, Engine: Owner, Classic Roadsters II
I don't see any reason why you can't use a good pan such as a Canton road race pan with baffles on both sides, 7 or 8 quart. A good windage tray to keep the oil off the crank. If you wanted to be real safe you could install a good oil accumulator. If the oil pressure ever drops below a certain pressure the accumulator will supply oil until you can shut down. The road race pan would also be good for the street.
Don
Old 05-16-2002, 05:53 PM
Mr.Fixit's Avatar
A good wet sump is fine. Get a diamond louvered windage tray, have it ftted to the crank / rods. And an oil pan with trap door baffling that holds at least 6 quarts. We run these to 7000+ all day long with out problems of any kind.. You really don't need a dry sump oiling system.
HTML code is On
