SUPPORT OUR SPONSOR
Old 06-13-2002, 12:29 PM
got snake?'s Avatar
Cobra Make, Engine: 396 long block, PROBE Forged Dished pistons 8.75 to 1 and Vic Jr. heads from Engine Factory. Tremec TKO. BDR#244 Sterling Gray/Silver stripes. 17in polished wheels, glove box and tonneau cover.
Default Winter...Oil cooler, Radiator, Trans cooler
Chicago winters are brutal...What kind of set up should I look for to keep things cool in the summer and warm enough in the winter?(will drive/start cobra once a week during winter)
Any suggestions?
Engine will be 351 crate or 392 crate.
1 Puller fan on the radiator is all I know for sure.
Should I invest in an engine heater....or a good electric blanket?
GS
T.S.B. of The West Side Cobra Club
N.D.N.P.N.P.
Old 06-13-2002, 03:52 PM
Bypassing the oil cooler or using an oil thermostat would be a good idea. I wouldn't worry about bypassing the trans cooler if it's built into the radiator - in fact, it'll help heat the fluid up to working temperature.
If you are using a rear-mounted battery, use 0 gage or heavier, and the block heater might be a good idea if you're not using a heavy duty starter.
Wear a hat and gloves - but you probably already knew that.
Bob Putnam
-E.R.A.-
Please address parts inquiries to eraparts@sbcglobal.net
Old 06-13-2002, 04:06 PM
got snake?'s Avatar
So no Oil Cooler is needed? Sorry Bob I'm a little slow
And I don't need the trans cooler cause it will warm up faster in the winter...right?
GS
N.D.N.P.N.P.
Old 06-13-2002, 05:09 PM
Bob In Ct's Avatar
Cobra Make, Engine: SPF - 351W, 944 non-turbo
Hey GS:
My best advice is to use a 0w-30 or 5w-30 synthetic.
I live in Connecticut and before I start ol' SPF642 in the winter I put a 60W light bulb under the crankcase the day before to help warm the oil. I put a piece of foam rubber in front of the oil cooler and I cover the bottom half of the radiator with foam so that the water entering the block is a little warmer than ambient.
Bob
Old 06-13-2002, 05:26 PM
got snake?'s Avatar
Thanks Bob! I was looking for something simple. And I also don't want to buy something that I don't need. If I'm not gonna use it why buy it?
GS
N.D.N.P.N.P.
Display Modes
HTML code is On
