SUPPORT OUR SPONSOR
Old 09-04-2002, 06:28 PM
kountzecobra's Avatar
Default Fan Wiring Question
I purchased a temp switch for my electric fan. It screws into the block and goes to ground at 185 degrees. I have no wiring info on it. Should I wire it into the ground on my Fan motor or should I wire it into the ground on the Fan Relay? Relay kit was from Painless Wiring. Also, how can I wire an override switch into the circuit? Thanks, David.
Old 09-04-2002, 07:10 PM
I would have the temp switch ground the relay. Tie into this same circuit, run to a switch and ground the other side of the switch. This will give you the an on-off that will bypass the temp control switch. When the switch is off, the fan will still work by temp control.
Old 09-06-2002, 01:26 PM
Cobra Make, Engine: Former owner of an A&C
Kountzecobra,
This may (or may not) help.
Painless Fan Relay Link
Old 09-07-2002, 08:19 AM
Thanks guys, I went ahead and wired the temp switch in the relay ground and also installed a bypass switch on the dash. Works like a champ! Later, David.
HTML code is On
