| S |
| 1 |
5 |
| 8 |
12 |
| 15 |
19 |
| 22 |
26 |
| 29 |
30 |
31 |
11-04-2003, 01:20 PM
TX
Oil Filter Flow question
This is a pretty stupid question, but that never stopped me before. Which way does the oil flow through the filter? Is it in (from the oil pump) through the smaller holes around the circumference, then out (to the bearings, etc.) through the larger hole in the center, or vice-versa? I was looking at a filter last night and couldn't believe I didn't know the answer, but I guess I was sleeping in auto shop the day we discussed the engine's lubrication system.
Advertising
11-04-2003, 01:33 PM
UK
Cobra Make, Engine: Crendon, windsor 408 stroker, tremec. Also GSX008
The first way you said it - into the filter through the outer ring of holes, back into the engine through the central one.
Get it wrong on your remote filter setup and bingo! No oil feed to the engine (but quite possibly good pressure on the guage!).
Wilf
VIC
Cobra Make, Engine: Real: Southern Roadcraft, SRV8, 351W stroker
filter flow
In through the small holes and out the center.
Bryan
COB-66 Young at heart old fart.
Don't drive faster than your guardian angel can fly.
If it doesn't matter what gear your in you have enough torque.
VK3KDN
11-04-2003, 01:37 PM
TX
Thanks! Since both replies came from overseas, maybe I'll delete this whole topic before America realizes how ignorant I am.
11-04-2003, 01:52 PM
Cal
too late snakeeyes
11-04-2003, 01:55 PM
TX
In my best Homer Simpson voice: "Doh!"
11-04-2003, 03:35 PM
CT
Cobra Make, Engine: SPF - 351W, 944 non-turbo
You would be amazed how many have plumbed it (incorrectly) in through the center hole. If the pressure sensor is in front of the filter very high pressure reading, if the sensor is after the filter, zero.
Bob
11-05-2003, 02:42 PM
Q
Andy the butcher had his oil lines to/from the sandwich plate back to front, and it cost him a couple of rebuilds.....
http://www.cobralads.com/butcher55.html
Craig
11-05-2003, 03:15 PM
SC
Cobra Make, Engine: Superformance, 396 CI
for the standard screw on filter, correct above, but for some racing, custom type filters, like the Canton Mecca, it is the other way. It is the "antidrainback" valve under the circle of small inlet holes that keeps the oil from back flowing to the motor, if mounted in reverse. This "valve" is usually a nytrile or other material large gasket, you can see it under the small holes.
here is what it usually looks like:
http://www.wixfilters.com/productinformation/index.html
hal
Hal Copple
Stroked SPF
"Daily Driver"
IV Corps 71-72, Gulf War
11-05-2003, 03:17 PM
CA
Cobra Make, Engine: Classic Roadster/428CJ "The Stretch Limo of Cobras"
Ahhh, errrrr, Hey not that I really need to know and this question is really not from me (?), BUT:how much "high oil pressure" would the gauge be reading? Also, if it was plumbed incorrectly, would the oil still be circulating from the engine to the external filter then through the oil cooler back into the engine?
Bob
A person who is nice to you, but rude to the waiter, is not a nice person. (This is very important. Pay attention. It never fails.)
11-05-2003, 03:40 PM
CT
If plumbed backward the pressure reading would be about that of the pressure relief valve. The oil flow would be close to zero!
Bob
11-05-2003, 06:32 PM
OK
Snakeeyes,
I think they are talking about me! BIG MISTAKE to get it wrong. It is amazing how fast an engine will melt down when it is done wrong.
Listen to these guys they know what they are talking about.
Flow is in through the outside of the filter and out throug the middle tube. Also, if you replaced or removed the gasket between your block and your adapter be sure you have installed correctly.
Clois
"Let's roll"
"Be part of Something Good
11-06-2003, 07:41 AM
TX
Clois, if I admitted half of the dumb things I've done in the garage I'd never be able to show my face around here again! I definitely fall into the "learn something new every day" category. In my case, I just have to hope I learn the "something new" before I do irreparable harm to my cars--
11-06-2003, 08:49 AM
CA
Snakeeyes,
Don't feel bad. I spent half an hour researching my remote setup before I hooked it up. And I had the diagram that came with it showing which line is the in and which is the out and the block and remote adapter were both marked with an in and out whith an arrow pointing that way. Iam easily confused and my remote filter mounting has 4 in and out lets. That way, depending on how you have to mount it for space you can come in either side and go out either side and then it had plugs to screw in and block off the two ports not used. I did know that with just the filter on the block, it went back into the motor throught the middle hole, but did I ever wonder about that remote set up. I finally had a man that does them come over to my house and check what I had done and he said I had it correct. A very rare occurance in my case.
11-06-2003, 09:08 AM
TX
Ron, at least you knew enough to ask somebody to check it. That may be the most valuable lesson I've learned--to ask someone who has a clue.  This site has been invaluable in establishing those kind of contacts...
Bob
11-06-2003, 09:21 AM
CA
Bob,
This club has helped me more than I could ever put into words. And through my mistakes I have managed to help a few. That is why I love this club so much. There isn't any question that someone can't answer even if they found out the hard way. I am fortunate to have three very knowledgable car people near me they can kind of keep me on track.
HTML code is On
