SUPPORT OUR SPONSOR
Old 02-10-2004, 09:21 PM
big_rob's Avatar
Cobra Make, Engine: FFR kit in the works
Send a message via Yahoo to big_rob
Default gasket removal tips
I’m changing from EFI to carb on this 302. i just removed the lower intake manifold and peeled of the old gasket left on the heads, but it left lots of residue behind is there an easy and safe way clean it with out the old gasket material falling into the heads (I don’t want to have to remove them)
and if you cant tell this is my first ever getting this involved in an engine so please be patient with me.
thanks
Big Rob The rookie
LITE'EM UP
Old 02-10-2004, 09:40 PM
Rick Parker's Avatar
Stick a crumled up paper towell into each of the intake ports, roll up a rag until it is about 1" in diameter and the length of the head. Lay it under the openings to prevent pieces of the gasket from falling into the area near the pushrods & lifters, carefully scrape the remnants of the gasket off. Then carefully remove the paper towels, collecting the small gasket pieces as you pull out each towel. Then use a hose from a vacuum ti suck any remnants out of the ports.
Good luck
Rick
Old 02-10-2004, 09:44 PM
big_rob's Avatar
what should i use to scrape it with i was using a putty knife but im afraid of scratching the heads
LITE'EM UP
Old 02-10-2004, 09:46 PM
big_rob's Avatar
and also whats the best way to clean the rust off the heads
LITE'EM UP
Old 02-11-2004, 03:18 AM
Cobra Make, Engine: Antique & Collectible 351 windsor bored and stroked tko tremec
also u can use a gasket remover aerosal can this can be purchased at any parts store. works great spray it on and let it set for a few minutes and old gasket s will come right off. good luck Neil in Maine
Old 02-11-2004, 05:41 AM
speed220mph's Avatar
Cobra Make, Engine: ERA 427SC w/427so, ERA GT #2002
Big Rob: First, do like Rick says and stuff the ports with rags or shop towels, but don't overlook any when you pull them out. And to prevent junk from landing in the lifter area, lay out shop towels to catch the junk when it falls.
Forget using a putty knife except for doing detail work. Use a dedicated gasket scraper . . . unless your heads are aluminum. Then you'll have to go another route. Rotary plastic bristle brushes used in a drill motor work great for this. Or, use a plastic gasket scraper.
As for cast-iron heads, use the steel gasket scraper. Be careful if you have to sharpen it and don't make the mistake made by a lot of people. The scraper should not have a sharp edge. Rather, the edge should be chamfered, one large ground edge, then turn over the scraper and chamfer the other edge. Looking from the end of the scraper, it should look like a V with one long leg and the other very short. And don't hollow grind the edges, but put a slight radius on them . . . both sides. This will keep the scraper from digging in. If you look at a new scraper, you'll see what I mean.
Once you're finished with both heads, carefully pull out the "plugs" from the ports, allowing the junk to fall into the lifer valley, then lift out the shop towels with the junk and you're done.
I hope you can follow what I said. There's no easy way to remove gasket material, just easier.
Tom
"If you can make black marks on a straight from the time you turn out of a corner until the braking point of the next turn, then you have enough HORSEPOWER." Mark Donohue
Old 02-11-2004, 06:41 AM
mickmate's Avatar
Cookies.....1/4" air tool with a 2" roloc abrasive disc (available in different grades). Cover and plug what you can, spray the dust from the gasket removal everywhere and clean and vacuum afterwards!
mickmate
http://www.actoncustom.com/
Old 02-11-2004, 06:56 AM
trularin's Avatar
Member of the north
Cobra Make, Engine: A Cobra
Rick Parker's setup is very good. I use rags and fill all the holes and then use a wire brush on a die grinder. Works great and will not fork this up.
You can grab a die grinder from Northern tool or Harbor freight for about $20.00.
Old 02-11-2004, 07:46 AM
MIKE SCHULZ's Avatar
Cobra Make, Engine: Contemporary 427 CCX 3627 ,TKO 600 RR,TWM 58mm DFI
People - PEOPLE!,....Please,The cavemen used scrapers and wire brushes. Try the 1/4" Diegrinder with the ROLOC wheel!,Slick as butter........Pretty soon you will be using it to shine your wifes silverware!!....It works THAT good!
Old 02-11-2004, 07:50 AM
I wouldn't worry about "scratching" the heads. They are iron after all and it would be extremely difficult to put any scratches on the surface that the new gasket couldn't handle.
Scrape away,,,, unless you got one of them fancy Roloc wheel thingies.
Ernie
Old 02-11-2004, 08:44 AM
Roloc wheel thingy, that's it!
Tom
Old 02-11-2004, 08:22 PM
big_rob's Avatar
where can i find a rolof wheel thingy i got the grinder just need the thingy
LITE'EM UP
Old 02-11-2004, 10:08 PM
xlr8or's Avatar
Do as Rick suggested with the stuffing of paper towels and rags for the lifter valley. Use the wire wheel on a drill or die grinder. If you have a helper have them hold the hose on the shop vac there as you clean. When done vacuum up any loose stuff and then keep it near by when pulling the towels and rags. Works like a charm and you can have both heads done in 20 minutes start to finish.
Old 02-12-2004, 06:12 AM
Banned
http://www.autobarn.net/mmm07480.htm...01&PID=1408109
Old 02-12-2004, 06:13 AM
big_rob: You can get Rolocs at most auto-parts stores such as NAPA. They come in various grits. I suggest you get a coarser one for cast iron and go finer with aluminum.
About using an air tool such as a die grinder, be careful when using a Roloc that the exhaust air doesn't blow a lot of junk into the rocker area. That's why a bulkier drill motor might be best when working on your assembled engine.
Use a vacuum as suggested, but just be careful not to suck up a rag or shop towel while you're at it.
Tom
Old 02-12-2004, 08:43 AM
trularin's Avatar
Member of the north
Got to love those "thingies." LOL
HTML code is On
