February 2026
02-28-2004, 08:39 PM
CO
Michael could you post pics of the wiring diagram and/or wiper assembly--I'm cheap  and I really don't want to buy a whole new assembly 'cuz now mine work just don't park?
02-28-2004, 09:53 PM
WA
I'll call my son and have him sort out the computer .I'll try to copy the diagram that Enzo sent with the switch.
The electric socket on the motor has five lugs, four verticle ,one horizontal
_ ground
I fast I park
I slow I fused ignition 12V feed
The top horizontal is a ground.Upper left verticle is fast speed,lower left verticle is slow speed,top right verticle isthe park from motor to#4 terminal on switch,lower right verticle is a fused 12V. I'll probably run the fused 12V power supply to the switch and back out of the same connector the supply to the motor .
Switch
1__ __2
3__ __4
5__ __6
7__ __8
#2 is Park returning from motor,#4 is fused ignition 12V feed
#6 is slow speed ,#8 is fast speed no blades in #3 and #5 on switch
I'll work on the diagram but I thought I was clever tring to make this display with what I knew.
Mike H
02-28-2004, 09:55 PM
WA
My attempt didn't work .When I submitted it it got shifted .What you are looking at isn't what or as I had typed
Mike H
02-29-2004, 09:49 AM
Tx
Michael,
I'm back from Austin early to avoid the rain. ( I drive my car to all events)
Sounds like you drank the Lucas Cool Aid  Welcome to the dark side
Steve
All my ex's live in Texas
02-29-2004, 02:16 PM
WA
I got the diagram scanned and put in as bmp file in my documents. It looks great. How do I get posted on this thread?
Mike H
03-01-2004, 12:30 AM
CO
Michael
Post the bmp file to your photo gallery, not sure how you post a text file into a thread, I still have trouble posting pics---you cna then open the file copy the link from the http at top of page then paste it into a thread text as a link.
Maybe one of the computer gurus can help----Ron?
03-01-2004, 05:54 AM
ME
Cobra Make, Engine: Shell Valley 351W Tremec 2004 Cobra SVT Convertible
Check out the pictures in my gallery and I have a diagram there that shows how you can use a double pole double throw switch with 2 relays to park the Lucas wipers. I used this on my Shell Valley and it works great. The relays are cheap from Jameco Electronics and they also carry the relay sockets (pigtails). It shows how to connect it to the Lucas plug also.
hog
03-01-2004, 10:56 AM
Tx
Hog,
I have used a two relay setup to operate the motor correctly from a G.M. steering column switch in a Classic Roadster. (Thanks to "PeteK" for the idea) To park correctly, Gary and Micheal would still need the park plunger switch on the motor.
Steve
03-01-2004, 12:39 PM
Tx
Here is the Finish Line diagram.
Steve
03-01-2004, 12:49 PM
Tx
Here is an alternative to the Lucas switch. It employs a modified Indak rotory switch. (Cost about $6.00) I hope you can read it. We'll see.
Steve
Hmmm.... That's just about useless. I'll have to re draw it.
03-01-2004, 09:37 PM
WA
I received the new wiper motor assy from Enzo.The park secret is the electric socket on the motor it looks like it slides into place.and is a built in cam operated switch.The motor has the same three wires that my original motor has but insted of the red wire going to ground mine came with the blue wire going to the contact designated as ground.The gear that came with the motor assy has a movable cam.It can be moved 180° .Where my old gear said 100° the new gear says 120°.My old motor was missing that socket -switch, I think that is the secret to self parking.All I had was the hole covered by a peice of electrical tape.
The new $43 switch has a very short threaded neck.I had to cut a rectangular hole in the metal dash to bring 11/16" by 15/16"part of the body into the dash then the threaded neck through the vinyl cover and washer.
It came with the electric plug to make a harness to the motor..Now to see if the conecters I have fit the plug. The previous schematic is the one I was tring to post.
OK I checked the 1/4" spade female connecters I have are too big soo I'm off and looking again. It is never simple.
Mike H
03-02-2004, 01:03 AM
This may help!
This is how I fixed my problem. I asked a Pro.
Hope this helps Guys.
Snake/Gerry.
The park circuit will work with the Chevette column if you wire it right. The manual tells you to ground the switch. If you do that you will pop the fuse every time you turn on the wipers. You need to remove the blue wire from the back of the park switch and ground it. Then run the rest of the wires like the manual tells you with the exception of the ground. It will work and park at that point. The other problem is tension on the cable. If you run the cable and cable housings too straight, the motor will spin past park every time. You need to tip the motor up to put a little pressure on the cable to slow it down. The park circuit will then catch each time.
Don
Snake,
This is going to be as confusing as hell. Pull the wiper motor out, remove the cover, pull the large gear... it should have a small white plastic tab on it approximately 1/2 long, on the flat side of the gear. This is the tab that makes or actually breaks the circuit so it parks.
Is it there? If it is, look on the opposite side of the gear and you will see corresponding holes. Pry the tab out of the original holes and reinstall in the other set. Reinstall and give it another try.
DV
Ok DV! Did what you said....changed the white tab in back of the gear....that was good advice...it works now...but I had to re-wire the plugs input for it to work...for mine the manual is wrong. This is how i had to wire it.
After switching the wires from the picture in the manual.
This is how they read.
Ground not used...use blue wire from lucas wiper motor for ground to cowl bar.
Constant power is now #149 and the other conected to Low speed wiper power...this one dosen't change from the manual.
High speed is now changed to #123.
After doing this everything works GREAT...parks perfect.
Thanks Everyone for the Help!!!
Snake
Hope this helps you's out.
Latter.
Snake/Gerry.
P.S If you need a better explanation, I am scanning the manual of the corrections...which may explain this better. If you would like a copy...just e-mail me at gm@mtl.clubplus.net
Snake/Gerry.
03-02-2004, 02:52 AM
Tx
Michael,
I believe those small female spade terminals can be had from Radio Shack.
Steve
03-02-2004, 03:00 AM
Tx
Snake,
" If you run the cable and cable housings too straight, the motor will spin past park every time."
Not if the motor is controlled electrically as Lucas intended.
"You need to tip the motor up to put a little pressure on the cable to slow it down. The park circuit will then catch each time."
Ahhhhhhhhh, Thaaaaaaaaat would explain why some people are getting away with wiring it that way. Thanks Gerry.
Steve
03-02-2004, 07:09 PM
WA
I went to Brooklands .They couldn't help with the electrical connectors.They aslo suggested Radio Schack.I'm going back tomorrow to see about getting the socket -switch actually on the motor.That would make even my old wiper motor park.
Sure would have been nice if the female connecters would come withe plug or available seperatly.They seem rather unique.
As far as the wiper motor socket-switch is concerned I can't be the only one who is missing it from a perfectly good wiper motor.
The $35 gear that Enzo sells will make the correct sweep 120°. IT is worth it, not having to alter the old gear and comes with the switchable cam to change park to left or right .
Mike H
03-02-2004, 10:33 PM
WA
Radio Schack doesn't have them.
Mike H
03-03-2004, 02:14 AM
Hey Steve R !
Hey Steve R! Glad I could help someone out...I had a lot of help building my Cobra...so I owe the favor. Club Cobra is the best...The best people and the best of friends.
Latter.
Snake/Gerry.
P.S If these guy's can't help you out...NO one can.
03-03-2004, 02:54 AM
Tx
Micheal,
Must be a lame Radio Shack. They are not all stocked the same. try another one. Do you have Ace Hardware out there? The one by me has a ton of bits and do- dads.
I could mail ya some if you can't find any.
Steve
P.S. Look back in this thread. I posted a source for the park switch. It is something like $15.
03-03-2004, 05:04 AM
Fl
Cobra Make, Engine: Hunter with a 4.6 supercharged
We picked up the termianls at Radio Shack, hate that place, and the ones they have do not have the locks for the plug so be sure they are fully seated and that your wires will not pull on the motor.
Bruce Edwards
Gemini Motorcars Inc.
http://home.bellsouth.net/p/PWP-GeminiMotorcars
03-03-2004, 01:28 PM
WA
Still looking for the terminals ,holding out for the locking ones.the size is .187" or 3/16". I know it will be found under some metric size in the end.
Brooklands had the socket-switch for the wiper motor.Out the door for $15.53.
Enzo says that lucas doesn't supply terminals.What is the point of the plug then?
Any suggestions?
Mike H
