SUPPORT OUR SPONSOR
Old 03-05-2004, 04:26 PM
Question Roll Bar/cage
I'm wanting to drag race my big block cobra. What kind of roll bar or cage do I need ? 10sec and slower---?
9.99 and quicker--??
Does any one make these.
Also, does any one have any recomendation on front and/or rear sway bars
thanks RC
RC
Old 03-06-2004, 08:47 PM
G.R.'s Avatar
Cobra Make, Engine: NAF 289 FIA, 347 stroker with Weber 48's, building a '48 Anglia gasser, driving a '55 Chevy resto-rod
Send a message via Yahoo to G.R.
Your best solution will be to check the rules governing your race venue--then locate a compotent Machine shop/ welding facility in your area and have them build/install what is required---some venues require full cages for "roadsters" others don't---FWIW
"Breathe in... Breathe out... then move on with life. Lifes too short to sweat the small stuff"
Old 03-07-2004, 05:57 AM
Club Cobra Member
Cobra Make, Engine: B&B 408W, TKO 600, 9" 4-link Truetrac, 13" X 1 3/8" curved vane frt disks
I'm also interested in suggestions about removable 4 point roll bars for road race open track days, but not neccessarily in compliance with any governing regulations. There was a car with this set-up at SAAC 27 California Speedway last year but I didn't get a chance to find out if it was stock or custom. To the best of my memory, it had side impact protection and was removable.
Old 03-07-2004, 06:02 AM
I'm running low 12s and the local track wants a six point cage. I went to another track and they told me that I just needed arm restraints. I have a single full width roll bar in the car now. If I remember correctly a car that fast will need to have the cage welded to the frame. I'm pretty sure that fast topless cars like yours will also need a tube that runs the perimeter of roof line.
I'm at the point where I want the bragging rights of 11's but don't want the full cage to detract from the beauty of the car.
Old 03-07-2004, 12:09 PM
HighPlainsDrifter's Avatar
Cobra Make, Engine: F5 Roadster
Arrow Rules.
RC,
Hi,
A good chassis/fabrication shop will be able to fabricate a 6 point rollbar, 3" above your head. Good to 11.00 at NHRA tracks.
You didn't say if you had a solid or independent rear in the car, anything faster needs a 9" solid rear end.The chassis shop will have to do alot of reworking to make your rear suspension hook up. Faster than 11 flat needs a full 10 point rollcage or a roadster cage welded in plus all the other safety gear, pick up a NHRA rulebook.
Anything faster than 11 flat in a cobra[ short wheelbase] is just asking for trouble , you should be thinking of another longer wheelbase car to race for stability and weight transfer.
Good Luck.
Perry.
Display Modes
HTML code is On
