SUPPORT OUR SPONSOR
November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 04-11-2006, 09:48 AM
Cobra Make, Engine: B&B, 396W Southern Automotive Stroker, Custom 8.8 by Fabrication Concepts
Default trany grind under rear wheel travel
I shreded a T5 and replaced it with the Tremec about 3000 miles ago. the fit was much tighter in my B&B but the geometry remianed pretty unchanged. I noticed that when it is up on the rack and rear end fully extended that the wheels wouldn't turn. Once the rear wheels were jacked up a little the problem went away. Not one to take the car airborne while driving I figured this would not be an issue. yesterday, i hit a long dip in the road under acceleraton and felt/heard a harsh grind through the shifter handle. any ideas on what is binding???
Old 04-11-2006, 10:17 AM
What kind of angle is the driveshaft in?
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
Old 04-11-2006, 10:23 AM
Send a message via AIM to mj_duell
Ditto. I believe you should be at 3 degrees with the car on the ground. With your wheels hanging, if the driveshaft is locking up my guess would be your tranny is at too high angle upward.
--Mike
Old 04-11-2006, 08:31 PM
all great comments and suggestions. when i installed the new tranny the position of the mount allowed the drive shaft to hit the frame so i had to put about 1/2 to 5/8 inch of washers to make it clear. i'm not sure what the resulting angle is but will check.
Old 04-11-2006, 10:21 AM
Cobra Make, Engine: Yard Dog FFR 521, 572 Fire Ant Mongrel Cobra 393, 566, Boss 600 hemi , RCR40 #13 348
Probably the driveshaft - exceeding the flex capability of the u-joints. FFR cars have restraint cables to limit the droop.
Note: the Tremec may have a taller rear mount than a T5, or some of the rear structure of the tailshaft may hit the frame. It can be trimmed as needed.
HTML code is On
