SUPPORT OUR SPONSOR
Old 05-18-2006, 05:05 PM
Cobra Make, Engine: 408w 500 h.p. 550 ft.lbs
Default Radiator Cap Pressure????
Just wondering what everyone is running for pressure on their rad caps.
I am using a 16lb. & I think I could stand to go a little higher, maybe 20lbs.
Any thoughts or suggestion would be appreciated.
I'm using all the usual stuff, aluminum rad, 408W all the good stuff.
Thanks in advance for help
Craig
Old 05-18-2006, 05:23 PM
*13*'s Avatar
Mine is 16
ERA FIA 2088
Old 05-18-2006, 08:02 PM
Cobra Make, Engine: StreetBeast 66 replica 302 350HP
mine is 16# also, are you having a boiling over problem, are you using a Stant cap
PapaJohn
Old 05-20-2006, 02:44 PM
It's filled the puck tank a couple of times over time, once just recently. it usually happens when i'm playing in the garage setting things up. Even when it doesn't appear to be overheating, thats why I thought a higher pressure cap may solve this problem. The car is fine when driving & in traffic, I always turn the fan on when in traffic no matter what the temperature. I would rather keep it from getting hot than try to cool down a hot engine.
Not sure about the cap although it has a large S on the cap & made in Mexico.
Is the Stant cap superior to others?
Thanks
Craig
Old 05-20-2006, 02:57 PM
Bob In Ct's Avatar
Cobra Make, Engine: SPF - 351W, 944 non-turbo
Seven pounds.
Bob
Old 05-20-2006, 05:41 PM
Cobra Make, Engine: Everett Morrision FE 427 so 2-4s
Next question ,How much pressure do you think the coolant pump seal will take?
Mike H
Old 05-20-2006, 05:59 PM
16 is plenty. The seal will hold well above that. I prefer to run the lowest pressure cap I can and not 'boil over' in a worst case scenario.
16lbs is around 250 degrees. IF your motor gets to 250 degrees you have other more serious problems than worring about your pressure cap 'blowing off steam'.
Old 05-22-2006, 07:03 PM
a stant cap is about as good as you can get, it usely has a little red leaver to let off steam, you maybe overfilling the radiator, once you fill it up let it puke out what it wants to and leave it be, if it doesn't run hot you are OK, you should try and keep it below 220f degrees, if you are running aluminum heads, they simply don't like a lot of heat
PapaJohn
HTML code is On
