Old 10-06-2006, 08:12 AM
sportyworty's Avatar
Default Spinner removal help!
Cannot get my spinners off. Tried lead hammer and the plastic shot hammer. Now have a flat spot on one of them. Any suggestions ? I want to get rid of the nasty tires.
Kirkham 004
Old 10-06-2006, 08:25 AM
SJK2's Avatar
Cobra Make, Engine: SPF#2189
Start with these threads:
http://www.clubcobra.com/forums/sear...earchid=176870
Steve
Old 10-06-2006, 09:41 AM
Bob In Ct's Avatar
SW:
Be sure you're hitting the spinners in the correct direction, look at the threads. I would do it with the tires off the ground. Use the lead hammer. Hit an ear, turn the wheel 120 degrees hit the ear and so forth.
The first time I took mine off it was very difficult. Just stay at it. Don't go nuts putting them back on, the pins take the torque load. Use anti-sieze and safety wire.
Old 10-06-2006, 11:39 AM
JBo JBo is offline
Cobra Make, Engine: Ex CSX3327, & AK7113 AutoKraft AC MK IV
Finish line has a nice tool for 195 dollars that spreads the load to all three ears atthe same time and makes the removal very easy.
Old 10-06-2006, 11:42 AM
double ugly's Avatar
Spinners come off in the same direction as the tires rotate when driving.
double ugly
Old 10-06-2006, 01:59 PM
Bob In Ct's Avatar
Not necessarily!
Old 10-06-2006, 03:50 PM
Exclamation
Thanks to all that replied . Several methods have been used with results just have to find the right one. The threads are not visible on the rears. The great news is I have the Goodyears i wanted. They will be on the car this weekend come Hell or high water. I will contribute to the thread the results.
Kirkham 004
Old 10-06-2006, 05:42 PM
Naumoff's Avatar
Originally Posted by Bob In Ct
SW:
This is the method I use. Works great.
I always remember back "on" so they unscrew towards the front of the car.
Screw on toward the back of the car.
Sometimes the can be stubborn but keep at it.
Bob you should have right hand thread knock offs for the drivers side and left hand thread knock offs for the passenger side.
Old 10-06-2006, 08:56 PM
G.R.'s Avatar
Send a message via Yahoo to G.R.
Turk's easy to remember formula for spinners... "Tight Ass" ...knock 'em forward to loosen...tighten them up to the rear..."Tight Ass"
Old 10-07-2006, 05:50 AM
Yetiman's Avatar
Cobra Make, Engine: Arntz/SBC/Jag
This all assumes his adapters were installed on the correct sides of the car...
We come into this world naked, screaming, and covered in blood. With dedication and a little planning, you can go out the same way.
View my overflow Gallery (much more to come !)
Old 10-07-2006, 05:52 AM
JBo JBo is offline
One recalitrant spinner on AK1113 took some gentle heat on the spinner body...this expands the spinner...and it came right off. Do not heat the hub
Old 10-07-2006, 07:42 AM
Naumoff's Avatar
Jbo,
Can you post some pictures of AK1113 in the gallery?
It would be nice to see your car.
Old 10-07-2006, 07:14 PM
JBo JBo is offline
If I can figure it out, I'll be glad to.
Old 10-08-2006, 02:34 AM
Naumoff's Avatar
Click on the little camera under your name.
Then click on upload photos.
Then browse button to find pics in your computer.
Double click your picture of choice.
Then follow the prompts as you go.
Hope this works for you.
Old 10-08-2006, 06:28 AM
Cobra Make, Engine: SPF #1507 427 Dart Block Windsor
I don't remove the safety wires until I'm ready to take off the spinners. Clip the wire, give the spinner a couple of raps with the lead hammer to get it started and then remove the wire. Then, with a gentle tap, you can always tell which way it needs to go.
When you're putting the wheels back on, seat the spinner and wire it before going to the next one.
Assuming you put the wires on the right way last time...
Lowell
Old 10-20-2006, 09:08 AM
Bob In Ct's Avatar
Hey Sporty:
Did you ever get the spinners off?
