| S |
| 1 |
5 |
| 8 |
12 |
| 15 |
19 |
| 22 |
26 |
| 29 |
30 |
31 |
10-06-2006, 08:12 AM
Spinner removal help!
Cannot get my spinners off. Tried lead hammer and the plastic shot hammer. Now have a flat spot on one of them. Any suggestions ? I want to get rid of the nasty tires.
Kirkham 004
Advertising
10-06-2006, 08:25 AM
Cobra Make, Engine: SPF#2189
Steve
10-06-2006, 09:41 AM
CT
Cobra Make, Engine: SPF - 351W, 944 non-turbo
SW:
Be sure you're hitting the spinners in the correct direction, look at the threads. I would do it with the tires off the ground. Use the lead hammer. Hit an ear, turn the wheel 120 degrees hit the ear and so forth.
The first time I took mine off it was very difficult. Just stay at it. Don't go nuts putting them back on, the pins take the torque load. Use anti-sieze and safety wire.
Bob
10-06-2006, 11:39 AM
Cobra Make, Engine: Ex CSX3327, & AK7113 AutoKraft AC MK IV
Finish line has a nice tool for 195 dollars that spreads the load to all three ears atthe same time and makes the removal very easy.
10-06-2006, 11:42 AM
az
Spinners come off in the same direction as the tires rotate when driving.
John
double ugly
10-06-2006, 01:59 PM
CT
Not necessarily!
Bob
10-06-2006, 03:50 PM
Thanks to all that replied  . Several methods have been used with results just have to find the right one. The threads are not visible on the rears. The great news is I have the Goodyears i wanted. They will be on the car this weekend come Hell or high water.  I will contribute to the thread the results.
Kirkham 004
10-06-2006, 05:42 PM
MD
Cobra Make, Engine: Unique 427 S/C 427 FE S.O. 484 cu in
Originally Posted by Bob In Ct
SW:
Bob
This is the method I use. Works great.
I always remember back "on" so they unscrew towards the front of the car.
Screw on toward the back of the car.
Sometimes the can be stubborn but keep at it.
Bob you should have right hand thread knock offs for the drivers side and left hand thread knock offs for the passenger side.
10-06-2006, 08:56 PM
CO
Cobra Make, Engine: NAF 289 FIA, 347 stroker with Weber 48's, building a '48 Anglia gasser, driving a '55 Chevy resto-rod
Turk's easy to remember formula for spinners... "Tight Ass" ...knock 'em forward to loosen...tighten them up to the rear..."Tight Ass"
"Breathe in... Breathe out... then move on with life. Lifes too short to sweat the small stuff"
10-07-2006, 05:50 AM
Wi
Cobra Make, Engine: Arntz/SBC/Jag
This all assumes his adapters were installed on the correct sides of the car...
10-07-2006, 05:52 AM
One recalitrant spinner on AK1113 took some gentle heat on the spinner body...this expands the spinner...and it came right off. Do not heat the hub
10-07-2006, 07:42 AM
MD
Jbo,
Can you post some pictures of AK1113 in the gallery?
It would be nice to see your car.
10-07-2006, 07:14 PM
If I can figure it out, I'll be glad to.
10-08-2006, 02:34 AM
MD
Click on the little camera under your name.
Then click on upload photos.
Then browse button to find pics in your computer.
Double click your picture of choice.
Then follow the prompts as you go.
Hope this works for you.
10-08-2006, 06:28 AM
Club Cobra Member
IL
Cobra Make, Engine: SPF #1507 427 Dart Block Windsor
I don't remove the safety wires until I'm ready to take off the spinners. Clip the wire, give the spinner a couple of raps with the lead hammer to get it started and then remove the wire. Then, with a gentle tap, you can always tell which way it needs to go.
When you're putting the wheels back on, seat the spinner and wire it before going to the next one.
Assuming you put the wires on the right way last time...
Lowell
10-20-2006, 09:08 AM
CT
Hey Sporty:
Did you ever get the spinners off?
Bob
HTML code is On
