SUPPORT OUR SPONSOR
December 2025
  #21 (permalink)
Old 04-05-2007, 08:33 AM
392cobra's Avatar
6th Generation Texan
Good info Dave,thanks.
Dumb question : Wouldn't you still be trying to draw thru 3/8" ? I think I'm misunderstanding something.
  #22 (permalink)
Old 04-05-2007, 08:53 AM
Cobra Make, Engine: Cobra-less
I went with the Holly 110gph mechanical on my 392W because I could not find a place I liked to mount an electric. On the BDR there isn't much room between the tank and other interferences to mount, let alone get a drill in there. I believe the wiring for their pump goes to the right wheel well opening. Did not want it there.
Hey Wayne, I'll be down in /Brawley/El Centro this coming week......Can you turn down the temp a bit?
AL
Cobras Gone But Not Forgotten
  #23 (permalink)
Old 04-05-2007, 09:58 AM
undy's Avatar
3/8" pipe is different from 3/8" tubing.. Pipe's measure ID (inside diameter), tubing's measured OD (outside diameter). The 3/8"MPT x 8AN fitting will give you full flow for your 8AN/1/2" system. You'll be fine..
  #24 (permalink)
Old 04-05-2007, 12:28 PM
WildBill3's Avatar
Default not electric here
were feeding a holley 830hp with a mechanical holley hv off a 1/2" line works great no problems we did redo the airbeeds after install runs great and very simple,i like that
  #25 (permalink)
Old 04-05-2007, 08:38 PM
Cobra Make, Engine: Everett Morrision FE 427 so 2-4s
Way over kill two Carter electric 15 psi 100 gal per hour pumps Y'd together with check valves to stop back feed. Seperate switches and indicater lites to tell if they are on.
Mike H
  #26 (permalink)
Old 04-11-2007, 05:51 AM
392cobra's Avatar
Thanks for the good explaination to my dumb question.
  #27 (permalink)
Old 04-11-2007, 05:57 AM
Cobra Make, Engine: Everett-Morrison, 347 Tri-power Stroker
Running the Holley red pump, (on my second one) - the only reason I put in an electric one was that Everett-Morrison has a provision for one in their stock wiring harness.
I'm not entirely comfortable with it since it doesn't currently have any type of oil pressure cut off switch. Will probably change to a mechanical pump this year.
- Dan
Display Modes
HTML code is On
