SUPPORT OUR SPONSOR
Old 03-23-2008, 09:05 AM
427 S/O's Avatar
Default Wiper motor
I bought two wiper motors, one is spare. There the early MGB/Triumph type with the wrapped cable in aluminum tube. I didn't hook up the switch because the wires from the motor are loose, about 5-6. Anyone know which wire does what?, I have a three way toggle switch for up-hi speed, down-low speed and middle off.
Thanks
Perry
Old 03-25-2008, 07:47 PM
Cobra Make, Engine: Everett Morrision FE 427 so 2-4s
I've been down this road before. Sorry I do not remember all the particulars. But if you do a search you will get all the pictures, wiring diagrams, explanations, and options I was given. It was great help. I used the Lucas switch and it all worked as advertized. FinishLine had a plug for the motor electrical but the snap in wire terminals had to be had elsewhere . You'll find it all there when you do the search and read. Lots aof printing.
Mike H
Old 03-26-2008, 01:35 PM
G.R.'s Avatar
Cobra Make, Engine: NAF 289 FIA, 347 stroker with Weber 48's, building a '48 Anglia gasser, driving a '55 Chevy resto-rod
Send a message via Yahoo to G.R.
Here you go try this link
Lucas Wiper
Sure helped me get my wipers going hi-low-park
"Breathe in... Breathe out... then move on with life. Lifes too short to sweat the small stuff"
Old 03-26-2008, 02:23 PM
427 S/O's Avatar
Thanks but, it dosen't give colors??
Perry
Old 03-26-2008, 02:54 PM
sharpe 1's Avatar
Cobra Make, Engine: Midstates,SBF 357
Try this web site
www.geocities.com/sprite-medget/wipers.htm
Good luck sharpe 1
Old 03-26-2008, 03:06 PM
Here's what you need- http://www.kirkhammotorsports.com/ma...permotor.shtml
I think the different years have different wiring colors. However, if you follow the wiring pattern on the motor connection, you should be able to hook it up. I just checked mine and it was correct.
You will probably have to buy the proper Lucas switch if you want your wipers to park.
Bob
Old 03-29-2008, 02:19 PM
427 S/O's Avatar
Thanks, I give it a try...
Perry
Old 03-29-2008, 10:16 PM
Club Cobra Member
Cobra Make, Engine: Rowen Replicar 351C wish it ran :) Anxiously awaiting delivery of my Road Serpent :)
Here is a schematic that came with the wiper switch from Finish Line. Just remember that the top post that is perpendicular to the other four is negative and you can easily figure out the rest of the wires. I used a standard 2 way switch (without a park) rather than the one from Finish Line because the one from finish line was about 14mm rather than ˝ inch and did not want to risk enlarging the hole in the finished padded dash. With the two way switch it takes a couple of tries to get the windshield wipers parked in the proper position but the car has never been caught in a rain so it probably doesn’t matter much. Before I put the either switch in, I “bench wired” the wiper motor with both switches. Both worked fine.
It is pretty straight forward. If this is not enough, let me know. Rick
Old 03-29-2008, 10:18 PM
Club Cobra Member
Oops! It did not come through. If you would like, I’ll email it to you.
Rick
Old 03-30-2008, 03:54 AM
427 S/O's Avatar
Yes, Please.
Perry
HTML code is On
