Old 12-28-2008, 08:43 PM
SuperHart's Avatar
Send a message via AIM to SuperHart
Default Leaking Thermostat Housing
There have been several mentions in the past about leaking occurring when using the small block thermostat housing that uses the rubber O ring seal. Just wondering if any of the members have been able to solve the problem WITHOUT throwing the O-ring sealed housing in the trash. In theory this style of housing should work well especially with ease of removal since there is no stuck gasket to fool around with.
I have closely examined the rubber O ring seals that come with these housings and have noticed a potential defect in some of them where the two O rings are fused together. I wonder if that is the source of the problem and if anyone else has experienced the same thought and devised a correction. Please don't tell me to trash the housing and get one with a gasket. I'm looking for any legitimate fixes, thanks.
Old 12-29-2008, 05:15 AM
Roscoe's Avatar
I use a silicone grease prior to tightening. Be careful and tighten the housing evenly. Any slight 'cocking' of the housing can cause leakage.
Roscoe
Old 12-29-2008, 05:37 AM
marcalan's Avatar
Cobra Make, Engine: era 289 FIA #2112
I use RTV on the o-ring where it mates to the surface of the intake manifold. I have this type of housing on two different vehicles now with no leaks. I have removed one of them once to change the thermostat and had no problem with removal or afterwards, just be sure to clean of the gasket material. I do not put a lot on, a thin layer seems to work.
hope this helps
live for the moment or it may pass you by
Old 12-29-2008, 10:55 AM
Banned
Originally Posted by marcalan View Post
I use RTV on the o-ring where it mates to the surface of the intake manifold. I do not put a lot on, a thin layer seems to work.
Same here. Hasn't leaked yet.
-Dean
Old 12-29-2008, 01:05 PM
CBattaglia's Avatar
Cobra Make, Engine: Gary Edwards Racing 460
Mine was leaking with the traditional gaskets. I switched to the O-ring and have had no problems since.
Its not the will to win that matters....Everyone has that. Its the will to prepare to win that matters.
Old 12-29-2008, 02:41 PM
Magic Goo:
Old 12-29-2008, 02:58 PM
w-lewis's Avatar
Cobra Make, Engine: Unique, 351W
I used a conventional gasket arrangement with a factory look alike overflow tank and it always leaked. About a year or so ago, I bought a FinishLine Overflow tank that used o rings instead of conventional gasket. It also leaked. In looking closer, I noticed the chrome thermostat housing was slightly warped a bit. You could place it on a flat surface and clearly see where you could slide a piece of paper under the center section, while the ends were firmly touching the table top. I planed down the surface till it was flat, reinstalled it on the engine and it hasn't leaked since........till now. I checked the two housing bolts and they were each about 1/4 to 1/2 turn loose. I tighten the bolts, drove the car once, parked it and it appears to be dry after about a week sitting up. Does anyone know the torque rating for the two thermostat housing bolts?
Walter
Old 12-29-2008, 04:23 PM
bobcowan's Avatar
I use the chrome piece with an O-ring that so many have had problems with. It looks good, so I think I'll keep it.
Remove the o-ring. Get a sheet of 120 grit sandpaper and place on a sheet of glass. Rub the gasket surface on sandpaper. That will produce a flat surface that has enough texture to grab ahold of a gasket. Then I use a standard off the shelf gasket, with a slight smear of silicone.
Like anything, torque the bolts evenly and to the proper torque reading.
Old 12-29-2008, 06:05 PM
SuperHart's Avatar
Walter, the water outlet bolts are 5/16x18 so they can be safely torqued to around 15 lb/ft. If using an aluminum intake manifold I recommend a little anti-seize cpd. on the threads to prevent galling.
Thanks everyone for the comments. I too like the O ring housings. When they work they work well. I especially like not having to scrape off gasket material whenever I want to remove the housing. I think I have just run through a string of bad luck lately with these housings. I checked two of them and both were warped. Looks like I need to do the glass pane and sandpaper routine. In the past I have used self-stick 220 grit on a glass pane with success.
