| S |
1 |
5 |
| 7 |
8 |
12 |
| 14 |
15 |
19 |
| 21 |
22 |
26 |
| 28 |
29 |
30 |
05-09-2009, 12:12 PM
CT
Cobra Make, Engine: KMP 736 Street, Pond 482, FAST XFI EFI
PCV valve connection help
Need some help here-
I have Blue Thunder Comp style valve covers and this is the PCV valve:
I would like to connect a rubber hose to it using a right angle connector. I found this at McMaster-Carr. It's a push-to-connect tube connector.
However, i'm not sure this can be used with a barbed tube. I believe it is for use with non-barbed tube connections as it has a steel ring inside the connector housing. The steel ring may not fit over the expansion of the barb.
Does anyone have any thoughts or other ideas?
Thanks.
phil
Advertising
05-09-2009, 12:54 PM
CA
Phil,
Could you take the steel ring out of the inside of the connector housing without ruining it and then just push the rubber part down over your PCV valve? I did that with a vacuum connection I had and it worked ok, but the steel ring inside my connector was easy to remove.
05-09-2009, 12:58 PM
Ca
Verify diameters and then chuck the barbed fitting in a lathe and remove the barb, very eazy, however the steel ring is probably formed of a piece of wire with ends and will expand.
Rick
05-09-2009, 02:45 PM
CT
Thanks guys. Those are good suggestions.
05-09-2009, 02:59 PM
CA
Cobra Make, Engine: Superformance 460 SVO
try a 90* spark plug boot
05-09-2009, 04:14 PM
wa
I answered your PM.
Mine is Fram FV191 PCV valve.
05-09-2009, 05:13 PM
FL
Cobra Make, Engine: Kirkham #570 w Shelby FE
If it's a spring loaded PCV valve you could simply use a 90deg pipe thread adapter.
05-09-2009, 07:54 PM
MD
Cobra Make, Engine: West Coast, 460 Ford Racing Crate w/ TREMEC TKO 600
I used a standard 429 PVC valve (Fram or Motorcraft ) from early 70's and it comes with a plastic elbow that you could remove and use in your application.
"...some assembly required, ages 8 and up...... well that took longer than expected......
05-09-2009, 08:10 PM
CT
These are all good suggestions...
Thing is, if you look at the picture, you'll see that changing the PCV valve isn't an option. The Blue Thunder Comp valve covers have a billet cap that screws into the valve cover. It's not push on. The PCV valve itself then threads into the billet cap. Best I can tell, the PCV valve is a Novo unit out of a 2001-2005 Toyota Highlander, believe it or not. So the bottom line is that I either just directly fit the hose to the barb, which will look weird, or come up with some sort of right angle arrangement.
Kitcarbp, I like your idea.
It's all in the details...
05-10-2009, 08:02 AM
wa
Get a standard cap from Blue Thunder and drill a .750 hole in it. Use the Fram FV191 valve and use some clear RTM to glue it in place. That is how I did mine.
HTML code is On
