SUPPORT OUR SPONSOR
Old 09-26-2009, 05:21 PM
EarlsflyinCobra's Avatar
Ouch Ouch Hot Sand
Cobra Make, Engine: Street Beasts w/302 Twin Turbocharged....Under Construction!!
Send a message via AIM to EarlsflyinCobra
Default Need help form a FORD wiring expert, PLEASEEEE!!!!
As stated in this thread....http://clubcobra.com/forums/showthread.php?t=99843.... I tried several times to no avail!
Upon reviewing my wiring I have found a couple of things that I am not sure about and will try to explain simply so they can be analized.....
I have an MSD dizzy and the plug has 6 wires in it....they are as follows;
1.....PIP.....which I have hooked to the Grey/White Crank Input #2 of the MT Unit
2.....SPOUT...which I have hooked to the Blue/Grey Output #0 of the MT unit
3.....Start....which I have hooked to the Pink Coil wire coming from fuse block
4......Run.....which is not hooked to anything
5.....Coil....which is hooked to the White wire coming from the HI-6 Ignition box
6.....IGN GI......which is hooked to Ground
Does this sound right to any of you FORD/MT Experts???? Should the RUN wire not be used?????
I am wondering if #4 should be hooked up, and if #3 and #5 should be reversed?
Safe Flyin, errrrr Drivin, Earl
Old 09-26-2009, 05:24 PM
Ouch Ouch Hot Sand
Also, can some one tell me what PIP is (other than Picture In Picture....LOL)
And
what SPOUT is (other than spouting off at the mouth)
Old 09-26-2009, 06:18 PM
Earl,
Are you working on a car or a smart mouthed TV
Anyway, I don't know d!ck about wiring, or a lot of other things for that matter. Especially since my stroke. Hope you get it fixed soon.
Terry
Old 09-26-2009, 06:33 PM
PANAVIA's Avatar
Earl --
OK, so lets start ( or try to) --
The MSD distributor if it is for an 86-93 5.0 calibration will run with the MSD BOX disconnected from the system, and the regular coil wires hooked to the coil.
1.-What harness are you running /using (Stock ford - Kwik, Ford Racing Etc )
2.- what computer A9L, A9M -- X3mu >?
3. list connections to car and where they go
4.are you running a check engine light<>?
5. How is your fuel pump being run >?
6. When you turn on the ACC (pre-start) do you see the CL and hear the fuel pump prime >?
Old 09-26-2009, 07:06 PM
Ouch Ouch Hot Sand
Ok, I will try and intelligently answer (LOL) your questions;
1. Kwik wire 14 circuit
2. MicroTech LT-10
3. I have a Crane HI-6 ignition box....orange and black from it go to coil, Large red to battery, black to ground, small red to 12v and white to the coil connection on the distributor. The PIP on the dist is going to crank input from the MT-10, the spout on the dist is going to Ign. output from the MT-10, the start on the dist is going to the coil wire from the fuse box, the run on the dist is not connected, the coil on the dist is going to the white (trigger) wire of the HI-6, and the IGN GR on the dist is going to ground.
4. No check engine light.
5. Fuel pump is run by LT-10.
6. Not sure what CL is and yes to hearing the pump run.
[QUOTEThe MSD distributor if it is for an 86-93 5.0 calibration will run with the MSD BOX disconnected from the system, and the regular coil wires hooked to the coil.
][/quote]
Not sure exactly what you mean by this statement??
I know just enough to get me in trouble.....LOL
HTML code is On
