| S |
1 |
| 2 |
5 |
8 |
| 9 |
12 |
15 |
| 16 |
19 |
22 |
| 23 |
26 |
29 |
| 30 |
03-12-2012, 05:05 PM
NJ
Cobra Make, Engine: BDR #1230/B2 445CI SBF
Need help-Distributor gear prob
Take a look: Heres the deal-Removed original MSD dist-replaced with the MSD Vic Jr model (slightly taller to clear intake). Car ran great for 100 miles then POP! Eng stalled out and this is what I find. I have a sick feeling in my gut. Gear on cam looks fine from looking down on it-little shavings in there from dist gear.
Any help? Thx
Gary Bowman
Voorhees NJ/Key Largo Fla/Ventnor NJ
03-12-2012, 05:32 PM
KY
Roller cam?
03-12-2012, 05:59 PM
NJ
Roller cam-It appears that the gear on the dist I used was cast which is not compatible with the cam I have. I need bronze or steel since it is billet cam, I hope I didnt damage cam gear.
Gary Bowman
03-12-2012, 06:05 PM
NJ
Gary Bowman
03-12-2012, 06:07 PM
KY
You should be able to tell by looking....any shiny or sharp spots on the cam gear?
DE
Cobra Make, Engine: Classic Roadster, 302, roller cam, Holley 650
Have a 302 motor with e303 cam. I had a bronze gear on the small billet MSD dist that did the same thing. Went with steel gear. So far things are ok.
The one line never heard in heaven; "Gee, I wish I had spent more time in the office."
03-12-2012, 06:12 PM
NJ
Cam gear appears fine from visual-now that i am looking closely at the dist gears they are def different material, the one i took out is steel and smooth where the one that came on the replacement is rough like cast would be. The flourescent green tag says "ONLY " for use with flat tappet....billet cams require a steel or bronze gear". My A.D.D. has struck again-I guess a few oil changes are in order.
Gary Bowman
03-12-2012, 06:14 PM
NJ
Foer Racing says to use Bronze but based on what J Stern says I am wondering to use bronze or steel?
Gary Bowman
03-12-2012, 06:27 PM
KY
Steel cams can use steel gears, bronze gears, or polymer gears. The bronze gears wear fairly quick. The steel gear would be my choice.
03-12-2012, 06:28 PM
NJ
Thx Bly-I follow your posts here and they are always informative and well thought. I appreciate the input very much!
Gary Bowman
Backdraft Racing Dealer
CT
Why did you have to change the distributor?
03-12-2012, 06:30 PM
DE
Brent Knows Best.
03-12-2012, 06:33 PM
NJ
Jay-the distributor was hitting the intake, MSD makes one specifically for the Vic Jr intake which is a bit taller but exactly the same otherwise. It was not installed on my engine so I changed it. No good deed goes unpunished  BTW I think my "bang is the trailing arm hitting the frame/body....if u look at it on the drive on lift, the front of the trailing arm is touching where the 2 bolts are. Do you think I can grind a little bit there?
Gary Bowman
03-12-2012, 06:36 PM
CT
Email me a pic directly ok?
03-12-2012, 06:48 PM
NJ
Jay I sent a PM
Gary Bowman
03-13-2012, 04:22 AM
MI
Magnet.
Borescope.
Lottery ticket.
Get as many shavings out as you can throught the distributor hole and oil pan drain plug opening.
Borrow a borescope if you can to carefully inspect the cam gear or small dental mirror and flashlight - my eyes ain't good enough to see well looking down that opening....
Lottery ticket is self explanatory
Steel cams are pretty tough - you have a good chance...
Survival Motorsports
"I can do that....."
Engine Masters Challenge Entries
91 octane - single 4bbl - mufflers
2008 - 429 cid FE HR - 675HP
2007 - 429 cid FE MR - 659HP
2006 - 434 cid FE MR - 678HP
2005 - 505 cid FE MR - 752HP
