Old 03-18-2013, 09:49 PM
Cobra Make, Engine: Kirkham - KMP493
Default Wet sleeves question
All, I am working on an engine project that is slated to use wet sleeves. Of necessity I have to have cooling passages in the flange of the sleeve that allow coolant to flow from the jacket below to the coolant ports in stock heads above. There are a couple of companies out there like LA Sleeves, AEBS and Eagle Manufacturing that put holes in the flanges of their sleeves. I know Darton does too. Does anyone have images of such holes in sleeve flanges that pre-dates October of 2001? Preferably these would be pictures of sleeves from anyone except Darton. My design is simple and I'm just trying to make sure I steer away from some very specific designs that are protected.
Much obliged for the help on this.
Old 03-19-2013, 02:58 AM
I just have images of Darton...
Can't you just use an existing sleeve?
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
Old 03-19-2013, 06:41 PM
I could, but I believe I can make them for less than I can buy them.
Old 03-19-2013, 07:31 PM
Jerry Clayton's Avatar
Years ago(sometime in 70s) I used to go around to John Deere dealers to get old sleeves from there farm tractors---they were very high quality material and the thousands of heat/cool cycles they went thru made them very stabile cores to use for machining into my race projects back then (Donovan and Rodeck ) blocks---also used some smaller bore stuff for the stock block Indy cars mid 80s-------
Old 03-20-2013, 07:39 PM
Problem solved. It appears that early 60's Triumph TR2, TR3, and TR4 engines were wet sleeved with precisely the feature I was looking for - a wet sleeve with a passage in the flange to permit coolant to move from the water jacket directly into a port in the head.
Rate This Thread:
