November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Like Tree11Likes
  #41 (permalink)
Old 08-02-2014, 05:53 AM
Got 'er done....
535 hp @ 5700, 562 lb-ft @ 4250.
750hp and jhirasak like this.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
  #42 (permalink)
Old 08-02-2014, 07:18 AM
750hp's Avatar
It won't make 560+ on this dyno. I've done several of these with the hydraulic rollers and they're generally at around 525-550 depending on the cam and intake work.
Right on! Looks like a really nice street combination.
Craig
  #43 (permalink)
Old 08-02-2014, 08:39 AM
impressive torque number at low rpm, that is a sweet spot build!!!
cdnus likes this.
  #44 (permalink)
Old 08-02-2014, 12:54 PM
crenbbf's Avatar
Got 'er done....
535 from a small block
Kinda gives the impression you know what your talking about
cheers Kiel
  #45 (permalink)
Old 08-02-2014, 03:03 PM
I'm impressed with the numbers too!
Jim
  #46 (permalink)
Old 08-02-2014, 07:25 PM
I'm really pleased with the torque, especially the peak torque rpm. Not too hard to get 650-700 hp out of these big windsors, but to make 560+ lbft at 4200 rpm and match it up with almost 540 hp does make me giggle a little. Smidge over 10:1 for that California swill, sounds really nice, and makes good power.
http://i170.photobucket.com/albums/u...psc29560cf.mp4
crenbbf likes this.
  #47 (permalink)
Old 08-03-2014, 06:48 AM
Chaplin's Avatar
Cobra Make, Engine: Original ERA 427sc, Powered by Gessford
Wow, that is a nice motor.
How low in the rpm range did the dyno measure? I'd be curious to know what the torque was around 3000.
Replica is not a dirty word.
  #48 (permalink)
Old 08-03-2014, 07:02 AM
At 3200, where the pull started, it had 539 lbft.
  #49 (permalink)
Old 08-03-2014, 07:07 AM
Chaplin's Avatar
LMAO, that is just silly good. That will be a ton of fun to drive. Great job!
  #50 (permalink)
Old 11-15-2017, 02:28 PM
Default air gap or vic jr on a 400windsor
looking into a ported rpm air gap for my street car.. 402w. any pros cons vs the stock vic jr manifold?
  #51 (permalink)
Old 11-15-2017, 02:36 PM
For that size engine, I'd use the Air Gap. It will have more average power and torque.
  #52 (permalink)
Old 11-15-2017, 03:22 PM
thanks.. where do I get one ported?
  #53 (permalink)
Old 11-15-2017, 03:24 PM
How much do you want to spend on it? Porting a dual plane can get into some bucks.
  #54 (permalink)
Old 11-15-2017, 03:28 PM
Neutral
like?
  #55 (permalink)
Old 11-15-2017, 03:29 PM
$250 for a port match and clean up, $500-750 on full port job.
  #56 (permalink)
Old 11-15-2017, 03:31 PM
is it worth it for that manifold? vic jr seems like the one to use on these strokers from what I have read on these forums...
  #57 (permalink)
Old 11-15-2017, 04:01 PM
Are you looking for hero numbers or for something that's best in the rpm range that you'll be running?
  #58 (permalink)
Old 11-15-2017, 04:04 PM
low mid range for street.. not worried about big hp numbers. torque moves the weight..
  #59 (permalink)
Old 11-15-2017, 04:05 PM
A Performer RPM or Air Gap will out run a Victor up until about 6200-6300 rpm.
  #60 (permalink)
Old 11-15-2017, 04:07 PM
sweet.. all I have read is go big with the vic.. you should know.. wish I had dyno my motor with both.. did you get my p m s?
Rate This Thread:
