Like Tree7Likes
Old 05-15-2018, 07:55 AM
Apex_speed's Avatar
Cobra Make, Engine: Superformance Mk3 with Roush 427R
Default OK to put temp senor in waterpump bypass line?
I have a Roush 427R with an Edlebrock dual plane intake. The intake only has 2 ports to the coolant passage and there is nothing on the heads. I'm doing fuel injection so I need the left front port for the FI coolant temp seder and the right port is my heater return. This will displace the temp sender for my coolant temp gauge.
I was just eying the water pump bypass hose that goes from the water pump housing to the fitting on the front of the block under the surge tank. Would it be OK to put an inline fitting in that hose so I can put the temp sender for the gauge there?
It is out of the way so it wouldn't be very obvious and looks like it is 1/2-3/4". I assume there is coolant flowing through this all the time that is reasonably close to engine temperature.
Thanks!
Old 05-15-2018, 08:11 AM
bingo2's Avatar
Cobra Make, Engine: RUCC, SB 331 Stroker
You can use a Street Tee (Google if you are not familiar with them) of the appropriate size, probably 3/8 NPT.
Old 05-15-2018, 08:28 AM
Apex_speed's Avatar
Yes. Mine is a bit larger so I was just going to use a tee that was gauge specific and flanged on either end as it is a rubber hose. Many of the gauge adaptors I have seen for smaller houses are widened in the point where the adaptor threads in so it doesn't create a restriction. I would probably try to find one of those.
Anyway, I take it that it is OK to tap into the bypass line and that the coolant flow there is constant and representative of engine temp? At least close enough for my dash gauge?
Thanks.
Old 05-15-2018, 11:02 AM
bingo2's Avatar
The Street Tee goes into one of the ports on the intake manifold and allows the use of 2 senders/sensors from the same port.
Old 05-15-2018, 01:30 PM
Apex_speed's Avatar
Ah, got it.
That setup doesn't seem to work well. I have had poor luck with them in the past and someone else on here put one on their Roush 427R and also had an issue. The gauge read much lower than actual temperature unless you turned on the heater so the coolant could flow past it and then it read accurately.
Have you tried one on an intake manifold port with good results?
Old 05-15-2018, 02:20 PM
cycleguy55's Avatar
Thanks!
IMO the question is somewhat irrelevant. If you're going EFI you should be running a single plane intake anyway, so ditch that dual-plane and get the proper intake.
Brian
Old 05-15-2018, 02:25 PM
Apex_speed's Avatar
It is a Holley throttle body injection system and both Roush and Holley claim the dual plane intake I have is best suited for the motor and system. Believe me, that was the first question I asked both of them!
msinc likes this.
Old 05-15-2018, 03:02 PM
cycleguy55's Avatar
Definitely wise to ask the question. I know some have had success with dual plane intakes, while others have had no end of grief. Best of luck whichever way you go!
Brian
Old 05-15-2018, 03:16 PM
Apex_speed's Avatar
Any idea of what the specific running issues were for the unlucky ones? I’m told that it’s no issue on a big or small block Ford but a disaster on an LS variant. Those have to be single plane.
Old 05-15-2018, 04:15 PM
bingo2's Avatar
I'm not certain what having a heater has to do with this. Put the tee in the other port on the intake manifold.
I have the Holley Sniper atop an Edelbrock Air Gap intake, which is a dual plane, and haven't experienced any issues.
Old 05-15-2018, 04:28 PM
Isn't there a gauge package for the Holley efi? Can't you mount that or wire in from the feed for the package?
Old 05-15-2018, 04:52 PM
Apex_speed's Avatar
I wish. It can run the Holley gauge packs which use a single data wire and there is no converter that I'm aware of to feed analog gauges. I'm not about to give up my Smiths gauges for Holley gauges.
Old 05-15-2018, 04:59 PM
Apex_speed's Avatar
Glad to hear it's running well for you.
The heater return hose IS IN THE RIGHT PORT of the manifold. If you put a street tee there, you can still attache the heater return to the top of the tee. BUT, I have had an issue where running the temp sender in an adaptor block (street tee) lifted it far enough away from the coolant flow that it didn't read accurately. This was not on a V8 though but a guy on here had a similar issue on a 427R. The heater comment is that when you turn the heater on, it circulates coolant THROUGH the street tee with the sender mounted in it and then would read more accurately (heater core does cool down the return temp a bit if the heater is on).
Anyway, I'm going to pick up a tee at the hydraulic supply house tomorrow when I'm there and try it. I suppose it's worth a shot and I can compare the dash gauge to the data in the Holley system to see if it reads reasonably accurately.
I suppose it's possible that the guy that had the issue had air in his system as that's about where it would end up as it's the highpoint.
Old 05-15-2018, 05:21 PM
bingo2's Avatar
I get all that but, you have two ports, the tee doesn't need to be in the same port as the heater fitting.
Old 05-15-2018, 05:57 PM
xb-60's Avatar
....I have had an issue where running the temp sender in an adaptor block (street tee) lifted it far enough away from the coolant flow that it didn't read accurately.....
I agree. I also had the same issue on my Alfa, using a tee to to be able to fit an oil temp sender.
The result of the sender being out in the air flow rather than in direct contact with the block or head was that it read way too low.
Glen
Old 05-15-2018, 06:10 PM
Neutral
I'm sorry, but why can't you simply weld on a new mount?
Old 05-15-2018, 07:01 PM
Dwight's Avatar
Smile
I needed a second water temp for my fuel injected (Eight Stack) system on my 302.
I drilled and tapped a second hole in the intake just behind the thermostat.
Dwight
Gaz64 and msinc like this.
Old 05-15-2018, 07:52 PM
Gaz64's Avatar
Dwight
This is the best option.
I've done this more than once.
The OP needs to find a location on the front of the intake, engine side of the thermostat.
Old 05-15-2018, 08:55 PM
Apex_speed's Avatar
Ok, how about we try this if you don't mind....where are the following located in your car?
1. Holley Sniper coolant temp sender?
2. Dash gauge coolant temp sender?
3. Heater return line?
Old 05-16-2018, 05:35 AM
bingo2's Avatar
No heater. The CTS is located in the passenger side port where the heater valve would be located and the sender for the analog temperature gauge is in the driver side port. I originally had them installed opposite of their current location but, I changed to more efficiently route the wiring; readings were identical from either location. If I did have a heater, I would try the tee in the driver side port and if it didn't function to my satisfaction I would drill and tap another port as others have suggested.
