Old 11-10-2003, 05:13 AM
Cobra Make, Engine: Superformance, 351 SVO #046
Default electric fuel pump
I have a SPF with a SVO 351W. The car is equipped with only a mechanical fuel pump. I would like to add a electric fuel pump to improve gas flow. Is it a easy install? Does it add to the engines performance ? I read the original cars used the electric as a booster" for the mechanical pump.
Gary
Old 11-10-2003, 05:25 AM
wilf leek's Avatar
Cobra Make, Engine: Crendon, windsor 408 stroker, tremec. Also GSX008
Gary - if your existing mechanical fuel pump is providing sufficient fuel pressure at WOT (normally 4-6 psi for a carb), then an electric one will not improve performance one iota.
Do you have symptoms of fuel starvation? If not, spend your money on something else.
WIlf
Wilf
Old 11-10-2003, 05:28 AM
Clois Harlan's Avatar
Easy ad on,
Wilf is right unless you just want another switch to toggle.
Simply locate your electric fuel pump within 12 inches of your fuel cell. Mine is located on the frame above and behind my rear axel as is my fuel filter. If you don't intend to use your mechanical fuel pump remove it and block the opening off with one of the triangle shaped chrome/alum fittings sold at AutoZone. A little fuel line to your carb(s) and your done.
Wiring: Red wire to Accy side of ignition key to a toggle switch terminal. Then coming off the other terminal take that wire back to your hot wire of the new fuel pump. The black wire from the fuel pump is grounded to your frame. Your good to go. Or you could just bypass the toggle swithch but I like to be able to bump my engine when I am setting my solid lifters without having fuel to my carbs.
Clois
"Let's roll"
"Be part of Something Good
Old 11-10-2003, 11:56 AM
Cobra Make, Engine: 427SC Unique
I would never install an electric fuel pump without a safety switch. Avail from Jegs or Summit and easy to install. I don't like FIRE
Brent
Old 11-10-2003, 12:18 PM
You are right Brent,
Lots of reasons to spend the $5.00 for a switch for the electric fuel pump. I am with you, I wouldn't consider an electric fuel pump without a manual shut off toggle switch. But you could wire it up direct with your key.
Clois
"Let's roll"
Old 11-10-2003, 01:19 PM
Cobra Make, Engine: Heading the 289FIA route, ERA is the choice du jour
Safety switch shuts off the pump in case of roll-over, like a mercury switch?
"Success discloses faults that failure would have otherwise concealed." J. S. Mill
Old 11-10-2003, 04:33 PM
Bob In Ct's Avatar
Cobra Make, Engine: SPF - 351W, 944 non-turbo
Unless you have fuel injection you don't need the electric pump. I would avoid it since Cobras have lots of hot metal around them.
Bob
Rate This Thread:
