LinkBack Thread Tools Rating: Thread Rating: 3 votes, 5.00 average. Display Modes
Old 08-14-2006, 04:15 AM
347's Avatar
347 347 is offline
Cobra Make, Engine: .
Default cfm
What is the CFM rating a single 44 idf weber?
My 347 has a 650dp, rpm air gap, 10.1 comp, 238/248@.050 solid flat tappet, 4.1 rear ,tremec, weekend cruiser.
If I was to change the 650dp over to twin 44idf's would I increase torque? hp? Or is it not worth the trouble?
Old 08-14-2006, 08:58 AM
Default Idf
why not go with something like this
http://www.twminduction.com/v8_kits/v8_kits-FR.html
Old 08-19-2006, 06:57 PM
347's Avatar
347 347 is offline
I would like to but I dont have the dollars.
Does anybody have any input or suggestions?
Old 08-20-2006, 08:15 AM
dlampe's Avatar
My 48 IDA's flow aroung 330 per barrell but go to individual runners. It doesn't sound like you have an individual runner set up. I think the IR setup is where the torque is created. If your 2 carbs are on a plenum shared by all cylinders, then I doubt you will see a big difference in torque. That is just my guess. It would still look cool!
High Maintenance Racing Team
Run & Gun 2003 - 2013
Old 08-20-2006, 11:56 PM
David Hodgson's Avatar
Given the Webers tunability, I would expect you would see some good improvements in torque and HP, but mainly driveability. The Webber can be tuned precicely right through the rev range where as a Holley is limited to main jet and pump squirters, unless of course you get one modified.
SLIPRY
Old 08-26-2006, 05:07 AM
Cobra Make, Engine: Cobra Daytona (from USR) 302RDI Yates headed + Weber induction
Weber CFM depends mainly of your ventury size (335 cfm for my 48IDF with 42mm venturis). Not sur that a Weber change will increase torque at low rpm significantly. Usually, Weber advantages are mainly between the middle to top end (according to your camshaft characteristics, I believe that expected Weber benefit will be between 4000 to 6500+ rpm). However, a 44IDF works well for a 289/302 engine but for a 347cid I think that a 48IDF with 40mm ventury will be more efficient.
Everybody agree that a good exhaust collector have to be designed with each pipe in the same length to be efficient. I believe that this rule is also applicable to the inlet manifold
