January 2026
4 5 6 7 8 9 10
11 12 13 14 15 16 17
18 19 20 21 22 23 24
25 26 27 28 29 30 31
Old 05-12-2009, 06:34 AM
Cobra Make, Engine: Contemporary, Shelby Alum 427, Dove heads
The dark color of the oil is most likely from assembly lube. I had the same black greasy magnetic stuff on my plug after the first couple of changes. I wouldn't worry to much about that on a new engine. The most likely failure is a bearing and they aren't magnetic. If you see a gold or bronze sheen in the oil then worry. Imagine 24 new rings sliding up and down in 8 new bores for 500 miles, you got to get some wear.
In school 90% is exceptional, in life 10% wrong is failure.
Old 05-12-2009, 05:24 PM
the motor is a crate engine from ford motor sport, 700 miles .
at this point i dont know what to think, i do see a goldish/bronze color in the oil that i drained, it somewhat shows in the pics i posted, im hoping that its not a bearing problem, if it is bearings what am i to see or hear from my engine, what signs, noise? the engine runs great an idels at 800/900 rpm and no noise, oil pres sits at about 40/45 psi at idle, and i put in 20-50 oil in it with a motorsport fl1-hp filter,
anyhow i guess i will just have to wait it out and see what comes of it, and see what comes out of the oil next time i change it,
Old 05-12-2009, 05:51 PM
Originally Posted by maxum_101 View Post
I'm hoping that its not a bearing problem, if it is bearings what am i to see or hear from my engine, what signs, noise? the engine runs great an idels at 800/900 rpm and no noise, oil pres sits at about 40/45 psi at idle...
If you have no noise and 45psi at idle I can assure you your bearings are fine. Bad bearings will drop your oil pressure and create a tell-tale noise that increases with RPM -- it's a whack/rap noise that even if you've never heard it before you'd recognize it as something that shouldn't be there. Do yourself a favor and quit thinking about this -- take your wife out to dinner instead.
Old 05-12-2009, 06:08 PM
DAVID GAGNARD's Avatar
zacctly, your worrying about mostly nothing.......On one of my motors I had the dark/black kunky looking stuff on the magnetic drain plug after a one hour dyno session, changed the oil/filter, ran that motor really hard for 4 years,no problems......
You should see less and less of this with each oil change...don't sweat the small stuff, enjoy the car........
David
DAVID GAGNARD
Rate This Thread:
