| S |
1 |
5 |
| 7 |
8 |
12 |
| 14 |
15 |
19 |
| 21 |
22 |
26 |
| 28 |
29 |
30 |
31 |
09-17-2007, 07:28 PM
DE
Cobra Make, Engine: SPF #2459 460ci, TKO 600
Temp sender???
Does anyone know the temp specs that the electric fans should come on and go off at. Mine comes on at 110*c, and turns off @ 105*c. Seems high to me, roughly 230*/220*f if my math memory serves me correctly. If I leave the fans switched on, stays at 85*/90*c.(about 195*f, more liveable)
Is there an adjustment on this system?
Thanks.
Thom
09-17-2007, 09:13 PM
CA
Change the switch in the radiator.
09-18-2007, 12:07 AM
CA
Cobra Make, Engine: SPF #633, 351w stroker, Tremec 3550
Fan Activation
Seems as if my fans engage at about 85 degrees.
Bob
"All that is necessary for the triumph of evil is that good men do nothing" - Edmund Burke
09-18-2007, 07:45 AM
Beam Me Up Scottie
MA
The owners manual says 95 to 97°C is when the fans turn on. Mine turn on when the gauge "indicates" about 90 to 93°C.
Your gauge "may" be inaccurate. But the standard radiator cap is only a 7 PSI unit. The owners manual says temps above 100°C during normal driving indicates a problem ... and if it goes to 110°C, shut off the motor and allow it to cool down.
Get something that will boil water in a small container, like those little electric coffee cup warmers or a hot plate. Remove the water temp bulb from the engine and put it in the hot boiling water ... your gauge should read 100°C.
If you have pure water in radiator and a 7 PSI cap, the water will boil in the radiator at 112°C (233°F). I use a 50/50 mixture of antifreeze and distilled water (NO tap water). I've never had a problem.
I do not know if there is any adjustment in the fan trip point.
Warren
09-18-2007, 08:38 AM
Banned
CA
Ditto here...that sounds about right. I typically hit the manual override switch at long stoplights to keep it below 90. I wore out THREE (!!!) of the cheapo Lucas 2-position switches and eventually swapped in some heavy duty units from Cobra Valley.
-Dean #747
09-18-2007, 10:14 AM
CA
An automatic radiator switch with a relay circuit ,with twin pullers is what I have had forever.Never a problem,runs right at 190.I may hit 200 on the hottest days in traffic.
09-18-2007, 11:04 AM
Banned
CA
Originally Posted by CHANMADD
An automatic radiator switch with a relay circuit ,with twin pullers...
FYI. Standard equipment on a Superformance.
09-18-2007, 11:48 AM
Mi
Cobra Make, Engine: Superformance 156, ex Paxton 351, now a 392 Ford Racing Stroker
my fans come on at 90-92 degrees C .... shortly thereafter go off as fans have done their thing - unless in slow crawling traffic .
I have a manual switch that i use in the heavy stop/go traffic . seldom has it ever reached 100 C on the hottest days and by that time the fans are on and again, shortly therafter they go off .
as others have said , perhaps your gauge is not accurate - or perhaps mine either . LOL . Bill
09-18-2007, 07:33 PM
DE
Thanks for the thoughts. I think I'm going back to square one and start all over. I am running a restrictor plate, not a t-stat, will switch to a 180 degree t-stat. I am only running h20, will put in a mix (50/50 anti freeze/distilled water). The car only has @ 130 miles on it, was just runninng h20 to make sure there were no leaks. May add a bottle of Wet Water. Running a 16 lb r-cap, that should be OK.
I'm still not sure how to tell if temp switch is off, or if the gauge is that far off.  If it can't resolve it, I will ask Olthoff, will be down there next week to pick up another car.
Sounds like I better pick-up a couple more Lucas switches to be ready
Thom
