Like Tree1Likes
Old 11-22-2010, 04:28 PM
Cobra Make, Engine: A&C Cobra, 521 CU BBF, Holley ProJection, T56 Magnum, 3.5:1 TruTrac 9-inch
Default Dingy Looking Intake
Hi Folks - was wondering what anyone has used to correct a dingy edelbrock aluminum intake on my BBF.
My cobra is nearly ready for street legal drive, but over the past year in the garage, the intake has gotten a little tarnsihed looking. Is there any kind of spray/etc I can use to clean it up? Or do I need to actually get it plated?
Thanks!
Old 11-22-2010, 04:37 PM
You could take it off and take it to a place that can bead blast it. It will look new, but will be a little raw. You would probably need to seal it with a clear finish or have it polished to maintain the nice finish.
Old 11-22-2010, 05:59 PM
Rick Parker's Avatar
Use some wheel cleaner approved for raw aluminum. Keep it off of anodized or plated parts.
Old 11-22-2010, 06:05 PM
thanks. i'll try a little wheel cleaner. most likely i will take off the intake for blast/plating, but it would be nice to clean it up a bit
Old 11-22-2010, 06:17 PM
Senile Club Cobra Member
If you glass bead it, take it and put it on a shelf to look at. No matter what you you do, you will NEVER get all the glass beads out of it. Gee, what will a couple of glass beads do when they hit the walls of your cylinders or better yet, get into you oil system and run around your main bearings a couple of times..........
rick@autoventureusa.net
Old 11-22-2010, 07:31 PM
Take it to a plating shop. Have them degrease and etch it. They might even be able to seal it.
Terry
Old 11-22-2010, 07:36 PM
Couldn't you seal off the openings with duct tape to keep the glass beads out and just blast off the outer surface? I've done it this way several times and it works fine as long as you use plenty of tape and make sure to seal it down properly.
Old 11-22-2010, 07:54 PM
Jerry Clayton's Avatar
Run it thru a dish washer cycle or two ---
Old 11-23-2010, 03:56 AM
thudmaster's Avatar
Regularly Offensive
Cobra Make, Engine: spf
Don't laugh too hard Jerry. I ran all four wheels from my Jaguar thru my dishwasher. After breaking the big chunks off by hand, my brand new Bosch dishwasher finished them off..............
Ed
Too close for missles, switching to guns.........
Old 11-23-2010, 06:48 AM
PatBuckley's Avatar
Assuming you don't want to remove the intake, you could try some Simple Green. Wet the intake, spray the stuff on, let it sit for a bit, scrub any stubborn areas and then hose off. 15 minutes max.
It may not clean it perfectly, but it is real easy to do.
Old 11-23-2010, 06:50 AM
Thudmaster
Ed---I'm not laughing, good to get some support for something simple like this---
Now----why THUDMASTER??????
Old 11-23-2010, 07:05 AM
This works pretty good, and the simple green wont hurt anything
Old 11-23-2010, 07:26 AM
thudmaster
How long did it take for the bruises to dissapear after the wife opened her new Bosh dishwasher to discover a big old nasty wheel in it??
Craig
Old 11-23-2010, 09:25 AM
NFLDMNBB's Avatar
Cobra Make, Engine: B&B, FR302
I've used the dishwasher with a small amount of Simple Green in the detergent tray many times. The very most important part is...... take the parts out before the wife can see what you've done!
Bruce.huling likes this.
Old 11-25-2010, 12:42 AM
joyridin''s Avatar
I use wheel cleaner for uncoated wheels. Leave it sit a few minutes, spray it off, and it looks like new.
I will admit, I have never tried the dishwasher.
Old 11-25-2010, 04:08 AM
Average Guy
The dishwasher picture is priceless. When I put VHT paint on my headers and put them in my wife's oven to bake, I went back out to the garage to work and forgot they were in there. When my wife got home, she came running out to the garage and asked why there was a "muffler" in her oven. The house smelled terrible. My bad.
Old 11-25-2010, 04:58 AM
awsome stuff! i'll try the simple green, although we do need a new dishwasher
Old 11-25-2010, 08:49 AM
ekrupa2's Avatar
When I had my intake off last winter I smoothed it down and had it Ceramic coated. Looks great and easy to maintain with glass cleaner and a more detailed cleaning with aluminum or ceramic coating polish.
Old 11-25-2010, 11:22 AM
Cobra Make, Engine: #010 SC motorcars 428PI TKO600
I used EvapRust, coat it on let it set for 15 mins then bush and hose off, brings aluminum back to new.
Old 11-25-2010, 01:13 PM
that ceramic intake is very nice !
i just sent my headers and sidepipes down to NitroPlate to get the shiny-ceramic. Can't wait to see them back
