Old 05-29-2005, 09:14 AM
Default Side Louvers
Hi im new on this site, i own a Pilgrim Sumo Cobra. I have salvaged this car from a shell. I have done all of the majoir work and now i am adding some finishing touches. I now wish to fit the Side louvers/vents. i have the two but i am needing help on how to fit them. Please help me with some infomation on how to fit them, Cheers Cam.
Old 05-29-2005, 10:27 AM
Tongue Pirate's Avatar
What do you mean by fit them? Are the holes cut in the body allready or are you trying to figure out the placement?
My car has two pieces of angle iron(or similar) epoxied to the inside of the body that the louvers bolt to. The bolts are not easy to remove or replace but I did manage with some patience. I'm guessing on the size but they may be 6-32 thread & they were button head SS bolts about 1/2" long with hex insert. 4 on each side.
Hyde D. Baker
Old 05-29-2005, 10:42 AM
Hi thanks for getting back to me so quickly.The holes are already cut into the bodywork its just that there is nothing to attach the vents onto they seem to fit ok but i need some sort of strong glue or bonding material.I have just tried to fibre glass them but that is proving to be very messy and i dont want to damage the paintwork.
Can you sujest anything?
Cameron
Old 05-29-2005, 01:12 PM
Yetiman's Avatar
Cobra Make, Engine: Arntz/SBC/Jag
If your going to epoxy them in, you need to thicken the epoxy. Epoxy alone won't be strong enough, and will run too much.
What you need to do is mix some 'wood flour' into the epoxy. The best source is if you have a palm sander with a dust collector, mix some of that extra fine saw dust in with the epoxy to thicken it. Besides thickening it and keeping the epoxy from running, it will make the joint much stronger.
I would drill a couple small holes in the pieces that will be attatching so as to hold better also.
Otherwise look into an epoxy product like PC-7 which may or may not be available where you are.
We come into this world naked, screaming, and covered in blood. With dedication and a little planning, you can go out the same way.
View my overflow Gallery (much more to come !)
Old 05-29-2005, 02:17 PM
zipzip's Avatar
Cobra Make, Engine: Midstates work in progress, personally built 302
I used fiberglass matting and plain resin to attach the brackets to the body. I'd suggest poking some holes in the angle piece or creating some other kind of "teeth" for the resin to hold to. I put the threaded rivets into the brackets 1st, then bolted them onto the louvers and held the whole thing onto the body by strapping over a piece of wood on the outside. Then I glassed in the mounting brackets. The only mess is getting all the drips before they harden. If you can work quickly, mix the resin a little hot to minimize the time before it takes a set. That'll eliminate a lot of the drips. A rag soaked in Xylol will clean it up nicely before it sets.
You might be a redneck if you think the National Anthem ends with "...Gentlemen, start your engines."
Old 05-29-2005, 03:45 PM
Cheers thats great info i shall try tomorrow thanks for the much needed help.
Cameron
