09-20-2010, 08:29 PM
KC 496 Completed/Dyno Results!
CAV GT40
Reason: Added Dyno Sheets
09-20-2010, 08:47 PM
Impressive, enjoy!
09-20-2010, 09:10 PM
VA
Ask him to post what the settings on the dyno were too. Were they zero'd out or "tweeked". See what the chassis dyno says when you get it home and on the street.
________
________
09-21-2010, 05:43 AM
Cobra Make, Engine: Shell Valley, 302 with NOS
Quite adequate Gary, as the Brit's would say. Your word is good enough on the numbers. Now to figure out some rear rubber to hold those horsies. In addition perhaps a package of Depends for the passenger seat! Drive Safe-Col
Under Promise and Over Deliver!
09-21-2010, 05:53 AM
Cobra Make, Engine: SPF2984 MK111, Roush 511 IR FE 8 Stack, Dynoed: [flywheel] 572HP at 6000 , 556# Torque at 4700, Bowler 4R70W Auto Transmision. Tires: Mickey T's S/R 26.0x10.0x15.0 F ,26.0x12.0x15.0 R Color, Bleck, because they told me it was Bleck, at the factory.
awesome specs
Originally Posted by gsharapa
Well Keith finished my 496 all aluminum FE, solid roller with stage 3 heads, victor single plane and Quickfuel 850........Dynoed at 681HP and 6700 rpm and 631.9 tork at 5,000 rpm. Ye Ha here we go....
Was going to post the dyno sheets but PDF files were too big to upload...will need to figure that out
Outstanding, now when you get it all hooked up, all ya gotta do is floor it, then please let me know what happened and what tires you had installed..Thanks, tin-man
Be well, drive fast, live long
09-21-2010, 07:09 AM
KS
Cobra Make, Engine: jbl
WOW! peaked at 6700, that is a pretty impressive setup for that many cubes. i'll bet the tq. was there from the start also. very nice. follow kc instructions and take care of her.
you know what the xpense is going to be now don't you, tires!!
09-21-2010, 07:58 AM
I have Goodyear Billboards on it so will start with those. I wanted a FE that would spin more like a small block and kill some of the tork down low. We went with a single plane victor manifold and Keith cut it down 1/2 inch for hood clearance and also a solid roller, stage 3 heads and aluminum flywheel. Keith knows I wasn't driven on HP but more the combination and what ever it came out at would be fine. I try to down size the dyno sheets and post them later today.
CAV GT40
09-21-2010, 08:48 AM
Gary slap it in & come join us in California for a break in !
Way too pretty here !
Wendell / Lynn
09-21-2010, 10:27 AM
Take pictures as I hear the cruising is fantastic out there!!
CAV GT40
09-21-2010, 10:36 AM
Cobra Make, Engine: Lone Star Classics #89 Keith Craft Genesis 427 so, stroked to 482, 649 hp. Sabre GT 40 #16 351W stroked to 408, 527hp, TWM stack injection, Fast XFI, G50/50.
Wow Gary, I cant wait to hear that beast. When is the install.
09-21-2010, 10:43 AM
Cobra Make, Engine: Kirkham and Hurricane Dealer in Mexico www.kitcarsmexico.com
Hi Gary, you need to show me that monster!!
Alfredo
09-21-2010, 05:07 PM
Ditto !
Going to be tough to wrangle the T I T crew with their race and cross country schedules. Let us know when to be there.
2011 TCC President
JSHEL1 on the Web
09-21-2010, 06:14 PM
Thinking the motor and trans might come over to Dallas next week as Rob told me they have another engine to go get next week and they probably will bring mine back also unless Keith is coming over to Dallas. Rob is doing my headers and side pipes so the plan is to take the car up there on a Saturday when Rob is available (he's racing with a NHRA Top Alco Team on most weekends) and just stick the motor/trans and he will keep it a couple days and do the headers/side pipes. I'll bring the car home and finish it while the headers and side pipes are being coated. I pretty much have everything now to finish the car.
CAV GT40
09-22-2010, 10:02 AM
Senior CC Premier Member
Hood Clearance? Don't forget this! (cheap plug, I know  )
http://www.clubcobra.com/classifieds...uct=3193&cat=2
09-22-2010, 02:57 PM
We took that into consideration and if you look at the pic I just uploaded in the begining of the post the manifold was cut down 1/2 inch which will allow for hood clearance. I love your base plate and once I get the motor in I will see if I need it. Probably will but I hate to buy one until I know for sure. Also need to check and make sure the 850 Quickfuel carb is same demensions as a Holley you developed the plate for......
CAV GT40
10-16-2010, 08:43 PM
Well finally got the heat shield material installed, frame and other parts touched up, air vents in and let's see what's next....engine!
CAV GT40
