Old 06-23-2011, 11:37 AM
SSSammy's Avatar
Default Trailer Wheel Alignment in DFW?
Can anyone refer me to a shop, preferably in the North Metroplex, that aligns tandem wheel trailer axles? My car hauler has one tire that is wearing the outside edge. I suspect the axle may need to be bent a little bit.
Thanks,
Sam
Old 06-23-2011, 02:31 PM
Thanks,
Sam
Sounds like the axle is bent if it's only one wheel. It would be easier to just replace the axle.
Old 06-24-2011, 06:58 AM
Call Joe at Thomson Tire in McKinney. He is the best old school alignment specialist in the Metroplex.
He will direct you to the right people.
I have had great work performed at Petro (sp.) Trailer in McKinney. Same day/next day work on our church's landscape trailer.
These two places are within a 1/2 mile of each other so it could be easy.
Paul
Old 06-24-2011, 08:23 AM
SSSammy's Avatar
Paul
Thanks, Paul .. just what I need.
redmt, I appreciate your comment. We'll see whether replacing the axle is necessary. I have had some input that simply bending the axle back into alignment is do-able.
Sam
Sam
Old 06-24-2011, 02:10 PM
Neutral
Sam
Sam
I'm never that lucky. When I bend 'em they're usually BENT. Most of the time it will be the right side front spindle from dropping the tire into potholes along the road.
Old 06-24-2011, 03:40 PM
Roush #1's Avatar
Cobra Make, Engine: Lone Star Classics / Roush 427 SR
Sam,
I have had trailer wheel alignment done previously in Waco at Central Texas Frame and Alignment, Inc. (they also have a shop in Waxahachie) and give them a very favorable recommendation if you can't find anyone in your area.
You are correct on fixing the problem...it is "doable"
J
Roush #1
Lone Star Classics
Roush Edition #01
Roush 427 SR #444
