1Likes
02-15-2012, 05:35 PM
Cobra Make, Engine: Factory Five MKIII Roadster
Poor Man's Lift
I thought I would share my latest project. I started with some plans I got from another thread here on CC, but did quite a bit of tweaking to the plans. They lift the car up a little over 10", so with 4" ride height the frame is up over 14".
I still have a few minor things to take care of like installing stop blocks on the front pedestals, painting, reinforcing the ramps with underneath support, pins to hold it all together, etc. Man that was a leap of faith driving up there. It doesn't look like much until your in the car going up the ramps!
FFR MKIII Roadster #5392
02-15-2012, 06:08 PM
Cobra Make, Engine: FFR from Levy Racing 302 FI w/Edelbrock Performer heads
Great idea. Hope you don't mind if I borrow you're idea. Can't wait for more pics.
thanks.
dave from mesa
Vietnam Vets may be eligible for medical care and disability compensation. Contact the VA if you have prostate cancer or type 2 diabetes. Finally got around to going to the VA.
02-15-2012, 06:10 PM
Cobra Make, Engine: Butler...488" hi-rise, dry-sump FE s/o w/stacks
Looks good to me....make a kit out of it and sell it.
Russ
02-15-2012, 06:11 PM
AL
lift
I would suggest adding a 2x4 in front of the front tires. It gives you something to stop the car. Of course you can jump across it but it has worked for me of several years.
Oh yes, pin the ramps, I shot one out but the car made it onto the stands. I made the pins out of fender washers welded onto 1/4" slick rod. You could use long 1/4" bolt.
Dwight
Reason: add comment
02-15-2012, 06:12 PM
Fl
Cobra Make, Engine: Antique&Collectible 392 stroked
I built the same lift but made it a little taller
pops67
02-15-2012, 06:29 PM
Cobra Make, Engine: SPF #1473 392 cu.in. titanium/black stripes
Here is a picture of my version of Red Barchetta's lift. There are more in my gallery. Additionally there is also a detailed build sequence for both Red's version and mine on Talk@CobraRegistry.comThey are on page 2 of "Cobra Builds" under the headings: "Cheap-O Lift" and "Poor Man's Qwik Lift For Under $250."
"Outside of a dog, a book is man's best friend. Inside a dog it's too dark to read."
Groucho Marx
02-15-2012, 06:30 PM
Dwight
I still have a few minor things to take care of like installing a stop blocks on the front pedestals
Thanks Dwight.. It's on the To-Do list.. Stop Blocks, Paint, Pins, Ramp Supports, Bolting to Floor, etc..
02-15-2012, 07:11 PM
AL
I don't have mine bolted to the floor. I take it apart and store it in the corner of the shop.
I have pins in the piece between the stands. Just drill a 1/4" hole and stick a bolt in it.
Dwight
02-15-2012, 07:41 PM
MD
Cobra Make, Engine: Superformance #2689 Roush 427R TKO 600
Harbor freight has some heavy rubber stop blocks, curved to fit the tire I think about $7, would work great! Fronts cold be ancored! Lifts look great!
B i l l
02-15-2012, 08:04 PM
VA
Cobra Make, Engine: West Coast Dreams
Danger! Will Robinson,
I had a Honda Prelude and I drove it up some of those metal ramps in my garage.... they scooted on the concrete floor, so I was a little more agressive. Yes, I overshot and boom! The front slammed down on the opposite side of the ramps... of course I may not have done that if I had a mirror or a spotter. It twisted up my mud flaps. I could not imagine what would happen if that was my cobra. I'd ruin my side pipes and do some body damage for sure.
I have a good floor jack and lift it up on to my metal ramps or on to wheel dollies. I don't drive any of my cars up on ramps any more. I'm lucky I learned my lesson on an old Honda.
02-15-2012, 09:36 PM
Your first mistake was driving a Honda Prelude!
Thanks, I'll just have to be careful.
Joe - -
02-16-2012, 06:25 AM
tx
Cobra Make, Engine: Lonestar Classics
$80 and trip to walmart. Reverse them so stops work both ways. Jack up rear, place ramps, then front. Plenty of room underneath for me.
2009 Lonestar Classics - 351 W
02-16-2012, 08:36 AM
Cobra Make, Engine: NAF 427
Hi randlej. Searched the walmart website but couldn't find your ramps. What are they called/part number? I'm headed over there this afternoon, so I'll look for them.
Greg
02-16-2012, 11:23 AM
tx
I've seen them at advance auto and other auto supply stores too. Not sure of brand, etc. They stack on top of each other very nicely when not in use.
02-16-2012, 09:13 PM
Those are definitely an option if you want to jack up your car. I really wanted to get away from having to always jack up the car. I plan to use mine as a permanent parking platform. I also wanted to be able to do alignments without having to continually raise and lower the car as adjustments are made.
02-16-2012, 09:30 PM
I'm with you Joe... I always park my car on my lift. It makes doing lots of cleaning and maintenance chores much easier. There is also more room under the car when you are on a creeper.
Groucho Marx
02-17-2012, 05:14 AM
Originally Posted by randlej
Attachment 19952
I don't understand that - lift the car and place ramps? Using jack stands would be easier and less costly.
DRB GT40 MK1 red #49- sold
SPF 2063
02-17-2012, 05:17 AM
Originally Posted by Stoney FFR
...I thought I would share my latest project...
Not only Poor Man's Lift --- it deserves the title Smart Man's Lift too.
Good job.
SPF 2063
02-17-2012, 06:06 AM
Member of the north
Cobra Make, Engine: A Cobra
Red posted his design years ago.
Good to see it is still being done.
I went to a Rotary when transmissions began to be a two man operation and I agged.
You can see the wood drive-up ramps against the back wall. I still use them, but the lift really makes it - IF YOU HAVE THE HEAD ROOM!!!
02-17-2012, 06:24 AM
tx
I have jackstands too and use them most of the time. However, there are times when you need to work on the car with wheels mounted and car weighted as if it were sitting on the ground. Setting pinion angle on the rear and setting ride height for example.
Don't get me wrong, I'd love to have a real lift.
