SUPPORT OUR SPONSOR
Go Back   Club Cobra > Club Cobra Tech Areas > Transmission Talk
Old 12-27-2009, 05:12 PM
Default Which Clutch Fork?
I have searched a hundred threads to no avail...
I have a 427 FE, TKO 600, Lakewood bellhousing, standard fork that clips into the BH driver's side pivot and the McLeod sealed TO bearing that clips on the end of the fork. I have been using a rear-mounted pull-type Wilwood slave which I do not like. I want to go with a block-mounted slave and keep the driver's side clutch arm and TO bearing. The arm I have was cut and drilled to suit the Wilwood slave, so I don't know if it would have been the right length for such a setup. Can anyone tell me which fork I need that will snap into the BH pivot and line up with the path of the block mounted slave?
Thanks.
Rate This Thread:
