Like Tree11Likes
Old 01-24-2018, 07:24 PM
FUNFER2's Avatar
Default Hydraulic Throwout Bearing VS Standard ?
With most Cobras having the hydro slave cylinder and clutch fork, will you feel a diffetence if changing to a hydraulic throwout bearing ?
Easier clutch pedal ?
Faster ?
Less engagment (inch's) needed ?
What all would be needed to use a hydro bearing ?
I have a 428, Tremec 600, Ram Force 10 billet aluminum flywheel & clutch and a Quicktime Bell.
AMERICAN POWERTRAIN HYDRAMAX HYDRAULIC CLUTCHES
Complete kit $660
FORD HYDRAMAX Hydraulic Clutch Actuator System for TKO/T45/3650/T5/T56/Magnum
Kevin
Old 01-24-2018, 07:30 PM
FUNFER2's Avatar
JEGS-
$275
McLeod 1434003QD
Hydraulic Clutch Conversion Assembly - Firewall
McLeod 1434003QD: Hydraulic Clutch Conversion Assembly - Firewall | JEGS
Kevin
Old 01-24-2018, 08:07 PM
twobjshelbys's Avatar
Already discussed (and recently at that). Some of us abandoned the HTOB system for a conventional system. I went through two HTOB before I gave up. Look at the slave cylinder setup by Mike Forte.
hauss likes this.
CSX4005LA
Old 01-24-2018, 08:26 PM
Gaz64's Avatar
Of all the hydraulic failures I see at work, I rather run a external slave cylinder.
Far less work if it fails compared to HTOB.
Mechanical on inside, hydraulic on outside. KISS.
xb-60 and ront49 like this.
Old 01-24-2018, 08:48 PM
FUNFER2's Avatar
Good to know guys. I'll look at Mikes setup.
Kevin
Old 01-24-2018, 08:59 PM
FUNFER2's Avatar
So, is this what you're talking about from Mike ?
Hydraulic External Slave For Steel Bellhousing
MLI likes this.
Kevin
Old 01-25-2018, 03:22 AM
Cobra Make, Engine: BDR Build #1054 351W stroked to 427
I installed a HTOB on my Backdraft Cobra and aside from the slight increase in pedal pressure I'm perfectly happy with the performance.
ront49 likes this.
Old 01-25-2018, 07:33 AM
FUNFER2's Avatar
Since it increased pedal pressure, why do you like it ?
To everyone, what are the pro's & con's ?
With manufactured cars, why don't they have the same issue's as aftermarket ?
ront49 likes this.
Kevin
Old 01-25-2018, 08:47 AM
If you can fit an external slave and fork, you'd be a fool to put in a HTOB.
Old 01-25-2018, 09:24 AM
The problem is that if there is any (and I mean ANY) misalignment then the gaskets in the HTOB fail, and if they do, it is a MAJOR task to fix, and you'll probably do it more than once. After #2 I just switched to the external slave and was done with it.
CSX4005LA
Old 01-25-2018, 11:15 AM
Texasdoc's Avatar
The pedal pressure can be changed with a different master cylinder. Mine was easier with the HTOB. But, like most, it started leaking. Had to take the transmission off to fix it. I decided I wasn't doing that again so I went back to the external slave.
ront49 likes this.
Old 01-25-2018, 11:34 AM
Dennis Mosley's Avatar
Cobra Make, Engine: Contemporary CCX33849 (currently 460)
+1 to what Texasdoc said, after having to take down the transmission to fix an issue, I converted my previous cobra to an external slave.
ront49 likes this.
The future is no place, to place your better days....
Old 01-25-2018, 11:35 AM
FUNFER2's Avatar
Sounds like a bad design, full of troubles and high cost.
Kevin
Old 01-25-2018, 01:32 PM
MaSnaka's Avatar
I switched to an external slave. It took some re-engineering but worth it in the end. Pedal pressure didn't change much.
Old 01-25-2018, 02:28 PM
FUNFER2's Avatar
How well does this type of system work in Kirkhams cars ?
Kevin
Old 01-26-2018, 09:06 AM
Cobra Make, Engine: owned Kirkham for 11 years
Kevin,
Both types work well in a Kirkham car.
I had a good 5 years on the McLeod internal until the throw out bearing failed and the gasket was toast on tear down.
I then used the Kirkham supplied external, everything included, for another 5 years with no obvious problem.
Maurice
Old 01-26-2018, 09:20 AM
Cobra Make, Engine: SPF GT40
Do not use a McLeod internal slave cylinder. Had mine fail 3 times on my GT40. Each time the o rings on the swivel joints leaked. Tilton or possibly others have a better design, but an external slave avoids all this. Had my external for 5 years now with no problems.
Old 01-26-2018, 12:56 PM
FUNFER2's Avatar
I'll keep what I have, don't want any issues, especially in such a pain dismantle area.
Like in many products, why is the hyd clutch in factory cars better than the aftermarket ?
Kevin
Old 01-26-2018, 01:35 PM
Cobra Make, Engine: Robnell Blown LS1
I have the Tilton setup on a TKO600 in my Cobra now for over 5 years with no issues at all.
Have just purchased the same setup to fit to the top loader in my 66 Fastback.
Is it possible that a lot of these failures are from not setting up properly in the first place? Or possibly incompatible fluid which swells O’Rings.
The Internal slave cylinders will also not tolerate over travel..Therefore a pedal stop I feel is a must.
hauss likes this.
Old 01-26-2018, 02:00 PM
FUNFER2's Avatar
I also have the Tilton setup, brakes and clutch & slaves.
I also agree that it could be their not done correctly built. Even something simple can cause big issues.
hauss likes this.
Kevin
