Like Tree1Likes
  • 1 Post By Rummy
Old 04-24-2020, 07:25 AM
Cobra Make, Engine: SMC, 427 Shelby aluminum block
Default output shaft seal
My Tremec t56 Magnum trans is leaking fluid. It is apparently due to a bad output shaft seal. I was told that due to a severe pinion angle of the driveshaft, a new seal may not work for long. Does that sound correct? I know nothing about transmissions and cannot see anything under the car without a lift. No jack will fit under the car either. I am in a rural area with no shops locally. May just replace the seal and sell the car.
Old 04-24-2020, 11:19 AM
67sn8ke's Avatar
Cobra Make, Engine: Shell Valley, 408 Stroker
I would think severe pinion angle would wear U-Joint's out more then anything and shouldn't have anything to do with the output shaft seal leaking. Changing the seal shouldn't be a problem if you can get your car off of the ground to get to it. Just my 2 cents!!
Old 04-24-2020, 12:22 PM
1795's Avatar
You may have to get a low profile jack, or you can try either over inflating the tires to gain some ground clearance or placing some two by tens on the floor and drive on top of them (that will gain you an 1 1/2" of height.
If the pinion angle is bad and you are getting an oil leak, then my guess would be that the U joints are starting to fail and that is causing excessive movement in the yoke which then is disturbing the seal on the output shaft.
Old 04-26-2020, 08:15 AM
Cobra Make, Engine: American classics 351 Windsor
I would try the seal first before getting too excited about anything else. It's inexpensive and a quick fix.
hauss likes this.
Old 04-27-2020, 09:27 AM
hauss's Avatar
Default silly seal
What he said. Could be a lot of things ,as long as you could feel no vibrations from the driveline you should be fine.
Old 04-24-2020, 05:09 PM
Build (2) wheel ramps from stacked 2x8's and drive up on them.
Just make sure the angle of incline is not too steep or the scraping sound will be most unpleasant.
This should provide a considerable amount of additional ground clearance.
Here's a DIY video reference:
https://www.youtube.com/watch?v=rQOIQVffO8o
2-1/2 ton hydraulic jack can do the remainder onto jack stands if needed.
Be sure to chock the front wheels if lifting the back off the ground or it will roll.
Old 04-24-2020, 08:28 PM
Gaz64's Avatar
Whenever I get a vehicle with a shaft seal leak, I check the shaft movement.
Many times, excessive shaft movement inside a trans bush, or pinion bearings, is the cause of the leak.
Poor driveshaft design could be wearing the trans output shaft rear bush and hence the oil leak.
Old 04-25-2020, 07:07 AM
Default Trans problems
Thanks to all who responded. I need to check the driveshaft for excessive up and down movement which would indicate the bushing is bad as well. I don't know if this is normal wear for the most part or what. I have ordered the seal but can't really find the bushing if needed. Any idea's as to where that item can be found? I've discovered since the trans is probably aftermarket Tremec as opposed to an OEM it's a crap shoot. Not even sure the seal I ordered is correct.
Old 04-26-2020, 12:55 PM
ERA 626's Avatar
just drive your front end up on a couple 2X4s then slide the jack under... I agree, the pinion angle has nothing to do with the seal... check for excessive movement.
Old 04-27-2020, 04:23 AM
Again, thanks.
