SUPPORT OUR SPONSOR
Go Back   Club Cobra > Club Cobra Tech Areas > Transmission Talk
December 2025
Old 02-28-2008, 06:02 AM
Cobra Make, Engine: Contemporary Cobra
Default world class t5
how can you tell a world class t5 from a regular t5?
Old 02-28-2008, 06:59 AM
LMH's Avatar
LMH LMH is offline
http://614streets.com/Worldclasst5.html
Old 06-20-2008, 04:11 PM
donraye's Avatar
Cobra Make, Engine: Street Beast "Grabber Orange"/Silver stripe w/418W 520HP full roller, T5. and: Backdraft #814 RT3B "Black Label" "Magic Black"/Sterling Grey stripe, 408W, full roller, 475HP, T5
Question What fluid for the world class/"z"spec T-5?
I just bought as Cobra with a 425HP 351 Windsor roller engine and a "World Class" T-5.
I'm new to Cobras and would like to know what is the preferred engine oil and trans. fluid for these units? Can I use synthetic oil in the 351 or does it prefer dino juice? I live in the SF bay area so what's good for the winter/summer in this area or do most of you run the same weight oil year round?
I've always run Mobil One in my high performance bikes and I use Castrol GTX in my 911 Porsche Air cooled boxer but all engines seem to have their own particular favorites and I have NO experience with Ford motors or transmissions so what's the scoop?
Thanks for any advice! Don
Old 06-20-2008, 09:03 PM
63mercury's Avatar
Cobra Make, Engine: Scratch building frame,FFR Mkll body ,302w, and T5 trans, 3.0 rear.
I have a healthy 460 in my Merc and use Castrol full synthetic since changing the break in oil. I use Castrol in all my engines and motors. Also I use Baldwin filters on the Merc and the Mfg'r filter on stockers.I read some tests on Fram and their junk. just my 0.02 worth on that subject.
The T-5 WC trans has what looks like a bearing cover on the opening just under the input shaft, it actually has a number stamped on it, if it looks like a soft plug than it's the STD version.
you can also download the service manual for that trans and it has good diagrams, I also have it on cd so I could froward it to you. Pm me if you'd like it. Carl
1963 Mercury Monterey 460+ .060 .//Cobra clone, Scratch build frame /302/ T-5 WC / 3.00-9in/FFR mkll body (Broken but repairable) /91 Lincoln Wire Wheels // : N.S.M.C Charter/Life Member// Die Hard Blue Oval Nut
The finish is better than the beginning. Ecc7:8
Rate This Thread:
