Go Back   Club Cobra > Engine Building, Tuning, and Induction > Weber Tuning
  #21 (permalink)
Old 01-12-2011, 11:15 AM
Junior Member
Cobra Make, Engine: 1980 Arntz 427W, Webers, TKO600, Jag IRS
RS,
The 18/21 was at 2500 rpm on the road. I,ll try the IR meter. When I get back in Feb. I,ll try the smaller idle jet. Now that the plugs are set I think the tune will be easier.
Tom
  #22 (permalink)
Old 01-12-2011, 05:24 PM
dlampe's Avatar
If you had popping while at cruising speed and not on deceleration or acceleration, you had a spark issue which you probably solved. By 2000 rpms you are well into the transition and the emulsion tube is starting to flow. I am running this setup,
idle 65
holder 100
Main 170
air corrector 180
F7 tubes
.50 bypass
40 chokes
Hydo roller cam .655 lift, 246 dur @ .050
on a 482 side oiler.
There is a hole between the main jets where you can see the float. My floats are 8.5 mm down from the top surface.
High Maintenance Racing Team
Run & Gun 2003 - 2013
  #23 (permalink)
Old 01-12-2011, 05:27 PM
dlampe's Avatar
Oh yeah, I ran an LM1 A/F meter and I am pretty solid around 13 to 1. I sat timing at 36 degrees, all in just off idle.
