1Likes
02-02-2011, 06:23 PM
AL
Air filter on webers
I would like to see pictures of air filter on Weber type of injection systems.
I do have the screens on the horns but I'm not sure that is enough.
I have Dynaformance fuel injection on my GT 40. I would like to install air filters. Or I could install screens on the intake ducts and seal off the horns from the air off the motor.
Pictures would help me decide what I want.
Pictures Please.
Dwight
Reason: add pic
02-02-2011, 06:46 PM
CO
I use these on the street. I'v never tested them to see what kind of power they lose.
I saw this one on a car at a show; I didn't get to speak with the owner. But I have heard it's available from TWM.
On the track I use these stacks, But I leave them open. The "Tea Strainers" cost me an honest 100hp, dyno proven.
This diffuser gives me about 8mph at the top end.
.boB "Iron Man"
NASA Rocky Mountain TTU #42
www.RacingtheExocet.com
02-02-2011, 06:52 PM
AL
Thanks Bob
do you think my Tea Strainers lose a lot of hp? My 302 should make about 375 max at the flywheel.
After I change a few things I'm going to the dyno.
Dwight
02-02-2011, 06:59 PM
AL
I'm limited on the size of the filter because
02-02-2011, 09:53 PM
CO
Originally Posted by Dwight
Thanks Bob
Dwight
I have read that the screens you are using do not lose much. They're supposed to be very efficient. Looking at your set up, I probably wouldn't change anything. I have considered buying some of those screens for track day.
.boB "Iron Man"
02-03-2011, 04:37 PM
I made these for mine.
02-03-2011, 05:55 PM
Cobra Make, Engine: Butler...488" hi-rise, dry-sump FE s/o w/stacks
jaspittman,
Very nice work. I think the trumpets affect performance in a positive way. Looks like your filters sit on throttle body. Do you have any idea if eliminating the trumpets has any effect vs sitting on the throttle body like you have done?
I suppose the bottom plate bolts to the throttle bodies from inside. Looks good.
Russ
02-03-2011, 06:16 PM
OR
I bought a screen to make my own box but just haven't gotten around to building it. These threads always have a lot of great options but nothing ever looks just right. No offense to anyone & their projects(many of them look awesome!), just that its tough to make something that looks as cool as a set of open Webers.
ERA FIA 2088
02-03-2011, 07:03 PM
AL
So Bob, do you think my filters are good for street driving?
I love the look of the open webers but I concerned about dirt in the motor.
jaspittman, I like the look of your set up. Is the base aluminum also?
Where did you get the filters? What size are they?
Dwight
02-03-2011, 07:38 PM
OK
Cobra Make, Engine: Fords
I love the look of the open webers but I concerned about dirt in the motor ............."
Dwight
a very legitimate concern. You can bore out a motor rapidly driving without air cleaners.
Z.
'65 K code Mustang
'66 Galaxie 500
02-15-2011, 06:53 PM
Originally Posted by SoTxButler
jaspittman,
The velocity stacks are still intact and stick up into the filtered area.
02-15-2011, 08:41 PM
AL
jaspittman,
do you have a picture of your filter with the top off? I would like to see how the velocity stacks enter the base. How far above the base?
Thanks for the picture. I want to build one like yours but not billeted aluminum. I was thinking of thin aluminum sheet with a small edge turned up to hold the filter. Sort of race car design.
What filters did you use?
Dwight
02-15-2011, 09:40 PM
CO
Dwight
Yeah, I wouldn't be concerned about using those screens on the street at all. Especially under glass like that. You're likely to suck in a leaf or a bird. Lets say they let in enough dirt to decrease service life by 50%. You'll "only" get 50,000 miles between major overhauls. That's what, 10 years? not enough of an issue to worry about.
On the track, I run open trumpets; and K&N's on the street. I overhaul the engine every 2 years or so. There's no measurable wear on the cylinder walls or crank journals.
.boB "Iron Man"
02-15-2011, 11:51 PM
As long as I can keep small children and flying squirels from being inhaled I'm OK. I think about the consequences of running without an Air Filter assembly, but just don't want to cover the carb bodies, which is what an efficient filter would do. They just look SOOOO good!
02-17-2011, 11:30 AM
I'm running IDF's, and this filter may cause you some clearance issues, but here it is anyway...
http://www.piercemanifolds.com/product_p/99217.434.htm
- Allen.
02-19-2011, 01:47 AM
Cobra Make, Engine: genuine 289 cobra (cox 6013)
Originally Posted by Fullchat289
Any pics of your nice headers ?
02-19-2011, 06:01 AM
Here's what I used, they come from Morrison Injection
Regards.
Mando
02-19-2011, 07:40 AM
KS
Cobra Make, Engine: jbl
speedway motors has a pretty good selection of filters for injectors in sprint racing, here is a small selection, their catalog has more or maybe find some more on the website.
http://www.speedwaymotors.com/Produc...irst_answer=65
04-21-2011, 03:31 PM
hi
i got these trumpets with screen filters on it
drive with them for more than 6000 miles... i have no problems with it...
why are you so worried to drive with "normal" screen filters?
04-21-2011, 04:33 PM
tx
Originally Posted by Mando
Regards.
Damn that cross ram looks nice!
ok, back to your regular programming.
