Go Back   Club Cobra > Club Forums > NW Cobra Club
Like Tree1Likes
  • 1 Post By t walgamuth
Old 07-16-2021, 06:21 PM
Registered User
Exclamation Tight Fit/Pedal Relocation
Hello , I'm new to the club and just bought a replica American Legend 67 Cobra.
It is a tight fit in the drivers compartment and the pedals are very close together , are there any relocation kits out there i can look at , ? Any help would be appreciated.
I'm 5'11 .seat is all the way back as well .
Thanks Dave
Old 07-18-2021, 05:26 AM
Cobra Make, Engine: Shelby, 1964 CSX2367, fully restored, I'm the second owner, SAAC Div 1 Premiere 2003&2012
I’m 6’4” and always have this problem in all my cars, and since I intend to keep driving fun cars I’ve tried many “fixes”. Some things I’ve done:
-set the pedal height as low as reasonably possible. This reduces the cylinder stroke so be sure the system is in fine condition. Make the brake and clutch pedal level.
-modify the seat track to move the seat rearward - even 1/2 inch helps.
-take some padding out of the seat bottom and back. This can really help.
-swap to a smaller diameter steering wheel. Helps give space for your leg when switching pedals. Makes steering when stopped difficult - wife may notice this….
-modify the actual pedals for more room. My XK120 has bottom hinge pedals, and I’ve installed brake and clutch pedal arms that are reshaped for space.
Good luck! Dave
Dave Wathen
1964 CSX2367
1938 Jaguar SS100
1953 XK120 roadster
1966 Etype roadster
1971 280SE 3.5 Cabriolet
Old 07-18-2021, 08:04 AM
twobjshelbys's Avatar
Driving shoes.
Tony
CSX4005LA
Old 07-19-2021, 08:32 PM
saki302's Avatar
Cobra Make, Engine: Superformance Mk3, Roush 427
When I had my factory five, I had to wear wrestling shoes or driving shoes as the gas and brake pedals were way too close together (mind you, I wear size 11, my feet aren't huge).
I can drive the superformance with almost any shoes now, except boots or wide slippers.
-Dave
Old 07-19-2021, 10:58 PM
To make a long story short, the overall re-engineering and labor to modify the existing car means it's probably cheaper to trade for a different car with better fit
Tony
CSX4005LA
Old 07-20-2021, 02:55 AM
t walgamuth's Avatar
I've done a lot of work on my VSE on pedal arrangment. I have sawed off an edge, added a solid block to one, heated and bent another. In my Formula Fords I have sawed off an edge at an angle to allow left foot braking. Adjusting the height will sometimes work.
The pedals have to be just right, especially if you are autocrossing or tracking the car. If you adjust your feet positions to turn or stop and your foot catches on a pedal or another foot you can be off the track in a blink. I can tell you it is very embarrassing scattering corner workers when things went awry.
I have some old leather sneaker style shoes which I have modified too, sawing off the edges and champhering them. This process is not all that expensive but it will take some money but mostly you have to think and then install and cut and fit until it works.
I ordered a new pedal cluster to use in the VSE but it didn't work and I sent it back. It is tricky business.
I went through a similar process on my steering wheel. Different diameters....I have a specially made 3/8" spacer. The cockpit in the cobra is very snug with no room for your left elbow except tight against your ribs. I wondered how the racers did it back in the day and if you check the old pictures you just very seldom see the elbow anyplace else....if its a fast car you learn to drive it.
....and I am not a really big guy....5' 8 and about 199#
As far as 2shelbys idea of trading rather than fixing....well, if I were buying today I would have a real specific list of things to check before purchasing as noted by another person, a half inch here or there can make a big difference.
Alfa02 likes this.
Old 02-26-2022, 03:57 PM
I just noticed I put in I weigh 299....actually it is 199.
