| S |
1 |
| 4 |
5 |
8 |
| 11 |
12 |
15 |
| 18 |
19 |
22 |
| 25 |
26 |
29 |
30 |
31 |
8Likes
03-08-2012, 05:06 PM
Vic
Originally Posted by Jerry Clayton
..... and you have support from a lot of other SPF not because your right but ]because there are so many of you that 1 % of the SPFers outnumber all the other owners totaled---
Your SPF are very nice cars, nice paint and upholstery, turn signals that don't work, windshield wipers that are grounded thru the dash and are questional , loose brake bolts, coil over mounts and adjusting collars---the engines and transmissions are repeatedly mounted solely to line up the side pipes with the body instead of the driveline-- oil coolers that just have lines stuck up into the fenders instead of actually hooked to the engine, underdrive pulleys to gain 5 or 6 hp, which then run the water pump and alternator too slow for cooling--- I could go on and on , but many of these issues are scattered thru out the replica cobra world, but a much higher percentage are on SPF---
Dear Jerry,
Firstly let me preface this by stating that I do find your posts to be quite helpful in general. But..
Sir, I am confused here... isn't this self-explanatory
If there are many more of them then it stands to reason that they would have a higher number of these occurrences.
I don't own an SPF but I know enough about them to know they make a great cobra and would consider myself privileged if I owned one.
Your post isn't reflective of the quality of the brand or car.
As for the word POSER - I find it a relative word. Used by some to take a position of superiority on others. You are welcome to call one a "poser" but you my friend may be considered a poser by another. Either way it can only comes across as inflammatory. Especially when the word be viewed from the point of its synonym "hypocrite". Perhaps the word "FAN" or "DEVOTEE" could also work here.
As for corner weighing of your car, I'd be happy to conclude that both parties are equally correct. If you feel your car isn't handling the way you want it to, or if you feel the need to - then go ahead knock yourself out!
03-08-2012, 05:12 PM
wa
Your SPF are very nice cars, nice paint and upholstery, turn signals that don't work, windshield wipers that are grounded thru the dash and are questional , loose brake bolts, coil over mounts and adjusting collars---the engines and transmissions are repeatedly mounted solely to line up the side pipes with the body instead of the driveline-- oil coolers that just have lines stuck up into the fenders instead of actually hooked to the engine, underdrive pulleys to gain 5 or 6 hp, which then run the water pump and alternator too slow for cooling---I could go on and on , but many of these issues are scattered thru out the replica cobra world, but a much higher percentage are on SPF---
Let's see. My turn signals work. Never had an issue with them.
Wipers? Never seen the rain, but I do try them out just to make sure they work, and they have never not worked.
Nope, no loose brake bolts, coil over mounts or adjusting collars.
Last I checked the engine is in the middle of the frame. Since they make their own headers I don't see any reason for them to offset the engine to fit a header.
Yep, my oil cooler is actually hooked to the engine. Missed again.
Okay, I have March undersize pulleys. Got me there. But then I have been in 105 degree heat and it runs cool. No overheating issues. They have one hell of a radiator/cooling system.
I'm starting to believe you have never seen a SPF in your life.
I do however have to agree with you that these cars are dangerous.
John Hall
03-08-2012, 04:44 PM
ca
Cobra Make, Engine: SPF roush 402
LOL....I'll agree with you there JC ,if my car catches fire I'm running, let'er burn.
03-08-2012, 05:11 PM
Ca
"Your SPF are very nice cars, nice paint and upholstery, turn signals that don't work, windshield wipers that are grounded thru the dash and are questional , loose brake bolts, coil over mounts and adjusting collars---the engines and transmissions are repeatedly mounted solely to line up the side pipes with the body instead of the driveline-- oil coolers that just have lines stuck up into the fenders instead of actually hooked to the engine, underdrive pulleys to gain 5 or 6 hp, which then run the water pump and alternator too slow for cooling---I could go on and on , but many of these issues are scattered thru out the replica cobra world, but a much higher percentage are on SPF"
Hey, I resent that remark. My rear shock brackets haven't broken.........yet!
Jim
06-11-2012, 04:40 PM
wa
Now what follows was really written by Patrick, but for once I could not argue with him.
Guys, this is a follow-up to close out the thread and, for once and for all, put the issue of "corner weighting your street car" to rest. As you all know, Patrick can be a pompous ass at times, has an inflated opinion of himself, and, from time to time, is a rude jerk not only to me, but to others as well. But, when a man's right he's right... and this time Patrick was absolutely 100% dead nuts right. After corner weighting my car, it does indeed drive noticably better on the street, and I have no doubt it will do the same under more agressive scenarios. In fact, I wish I had listened to him and done the corner weighting long ago. All the nay-sayers on this thread are just plain wrong; Patrick is right, along with everyone else who echoed his sentiments. And, while it pains me to say it, I have now done just that.
John Hall
| Thread Tools |
| Display Modes |
Hybrid Mode
