Like Tree1Likes
Old 06-12-2012, 03:00 PM
Default Do I need an FE side oiler?
Ok, any time I "hear" the 427 side oiler in any of the videos, it just sounds exactly like what I would want my own cobra to sound! Love it! Is the "side oiler" unique in some way or is it just my imagination that it sounds like no other? Do I need an FE side oiler or can I get this from another engine build?
I just love that roar and snorting and burble on overrun. example here.
2011 Super Snake vs 427 Cobra - BADDEST SHELBY EVER - YouTube
Old 06-12-2012, 03:47 PM
philminotti's Avatar
Cobra Make, Engine: KMP 736 Street, Pond 482, FAST XFI EFI
Any FE can have the sound you want. Side oilers are bragging rights. So, if cost is a concern, have Brent, Barry or Keith build you a nice FE based on a 428 or 390 block
Old 06-12-2012, 03:52 PM
rodneym's Avatar
Full Blown Member
Premier Contributor
You don't need a pretty wife, either.
rodneym
Old 06-12-2012, 03:58 PM
Grubby's Avatar
Cobra Make, Engine: ERA 838
Side oiler = bragging rights and $s
Old 06-12-2012, 04:00 PM
rodneym's Avatar
Full Blown Member
Premier Contributor
Grubby,
See post above.
rodneym
Old 06-12-2012, 04:03 PM
RodKnock's Avatar
Are we talking about an original sideoiler, a Genesis iron sideoiler or an aluminum Pond sideoiler?
The Shelby blocks aren't sideoilers.
Old 06-12-2012, 04:04 PM
Can we please elaborate on this for learning purposes? Don't you just love the new members?
Old 06-12-2012, 04:28 PM
Listen to Phil's advice above, and then click on the audio link in my signature below.
Old 06-12-2012, 04:44 PM
Sounds fantastic!
Old 06-12-2012, 04:47 PM
Originally Posted by PHC1 View Post
Sounds fantastic!
Now that's a solid flat tappet engine. You can hear the valves ticking and the "sewing machine" tune. I have had people ask me "is it supposed to sound that way?"
Old 06-12-2012, 04:53 PM
We love them more when they use the search feature for basic info and then ask smarter, SPECIFIC questions which we're all happy to help with. Instead of repeating the same basics over and over in a waste thread.
Where to look??
OH how about the FE TALK forum?
Club Cobra - Powered by vBulletin
Chas.
Old 06-12-2012, 05:00 PM
RodKnock's Avatar
Simply put the (Robert) Pond aluminum and Genesis iron blocks are the best and possibly only reproductions of the original sideoiler. They're all expensive assuming you find a nice sound original sideoiler block.
Old 06-12-2012, 05:23 PM
Notwithstanding chas' reply, the side oiler was designed to combat oil starvation to the main bearings on NASCAR superspeedways back in the day. Not necessary for the vast majority of applications. That being said, good FE blocks are getting harder to find, making the aftermarket blocks more attractive. It just so happens that two out of the three aftermarket blocks are cast and machined as side oilers. Hope this helps
Old 06-12-2012, 06:12 PM
Phil-Nice to see you make an ultra-rare appearance to weigh-in here and aid the new person.
Glad my reply prompted your participation.
Chas.
Old 06-12-2012, 06:20 PM
Where to look??
Fair enough, I should have asked this question in the FE TALK except I wasn't sure if I was asking a question that was actually related to an FE engine or some other specific characteristic that is responsible for the "sound" of the engine that I liked. I guess I am guilty as charged but surely there is much worse a guy can do???
Old 06-12-2012, 06:21 PM
Phil, RodKnock, Patrickt, thank you for your input!
Ha. Exactly!
Old 06-12-2012, 06:48 PM
SoTxButler's Avatar
Cobra Make, Engine: Butler...488" hi-rise, dry-sump FE s/o w/stacks
Just a couple of things to help you out:
1. 427 FE came in center oiler (sometimes called top oiler) and side oiler configuration. The Center oiler oils the valve train first and then the mains. The side oiler oils mains first then up to the valve train. The side oilers lasted longer in long distance racing and were configured that way because Ford was having issues with the center oilers losing the bottom end.
2. Some center oilers also had side oiler casting, just were not drilled. Early ones '63 & '64 did not have the side oiler casting.
3. All 427 blocks (center and side) were solid lifter blocks until sometime in '67 or '68 when the hydraulic lifter block came out.
They all sound the same..and unless someone gets up under your car to look at the driver side of the block, one one will know which one you have. Of course the above relates to the originals...not so familiar with the specifics of all the aluminum aftermarket blocks. In fact...all FE's sound the same...a 390 will sound the same as a 427 with the same cam, etc.
If you are only looking for the sound...get whatever one you can find, unless you are planning to go racing for 500 miles at a time...if so, you should probably try to get a side oiler.
I'm am not expert but hope this helps
jcooper likes this.
Russ
Old 06-12-2012, 07:14 PM
Dimis's Avatar
You need an FE about as much as you need a cobra
That said it be the only engine I'd consider for a Kirkham or ERA, but to each his own.
Old 06-12-2012, 07:23 PM
Yes, this helps a lot!! Thanks for the bit of history lesson too!
