Old 09-10-2012, 09:18 AM
Jerry Clayton's Avatar
A fact that most of are overlooking is that an oil pump will not pump more oil up/around/thru an engine than the clearances will aloww to pass---the pump has an relief valve that will bypass the oil flow and it will stay right in the pan---
Biggest issue with high volume/hipressure pumps are blowing oil filters when cold-----
Old 09-10-2012, 10:16 AM
Well, the pan is off along with the oil pump.
The pump has M84 cast into it, and either 211 or 214 cast in another spot, can't tell for sure which number it is.
The pump screen is clear, no cracks in the tube, and everything looks brand new as far up as you can see in the engine.
The vanes in the pump look new also.
I just don't think the pump is bad, But????
Last night I started the car again before I got it jacked up and the oil pressure cold was at 70 lbs, just like always.
Did see a drop of oil where the brass fitting screws into the remote casting that fits on the block. I took both fittings out and resealed them.
Thanks for all the help/suggestions so far.
I guess the nesxt thing is a new pump and Motorcraft filter.
Mike
Old 09-12-2012, 10:16 AM
Well, the oil pump is in with a new Motorcraft filter, and new oil.
Have 65-70 lbs of pressure when moving and about 50 when idling.
Can't beat those numbers.
Not sure what caused original problem, but all seems OK now.
A friend suggested installing an idiot light for the oil pressure as a back up.
Guess I'll do that just because.
Thanks to all for the answers and suggestions.
Mike
Old 09-12-2012, 10:31 AM
DAVID GAGNARD's Avatar
Mike
Oil pressure warning light is cheap and easy to install, have this one in both my street car and race car......everyone should have one......
20 Lb. Oil Pressure Warning Light Kits - Speedway Motors, America's Oldest Speed Shop
David
DAVID GAGNARD
Old 09-12-2012, 10:25 AM
CHANMADD's Avatar
That idiot light is soooo important.
Display Modes
