Old 10-01-2012, 02:53 PM
Grubby's Avatar
Cobra Make, Engine: ERA 838
Default Paint ceramic coating to freshen it up?
My car has silver colored ceramic coated headers and sidepipes. The side pipes are starting to show some wear after 8,000 miles and 4 years.
I am considering changing the color to semi gloss black. Is it better to send them out for a complete ceramic recoat or rough up and paint VHT or some other paint over the existing ceramic?
Have any of you painted over the ceramic and does it stick for a long period of time?
Does black coating or paint stain easy? That is a concern. The silver cleans up nicely.
Old 10-01-2012, 03:41 PM
fordracing65's Avatar
As long as you use a high temp paint, Iv'e done it that way before with no problems....
PRIDEnJOY
Old 10-01-2012, 03:48 PM
Mine clean up pretty well. I had a bad skin and sinew stain on my driver's side pipe, but I found that 409 cleaner took it right off.
Old 10-01-2012, 05:55 PM
DanEC's Avatar
The VHT hi-temp (+2000 deg) black I've seen is pretty flat. I haven't seen a hi-temp satin black paint yet. VHT makes caliper paint in satin black but it's only good to 900 degrees. That probably would be short lived up near the engine.
Old 10-01-2012, 06:29 PM
FWB's Avatar
FWB FWB is offline
i've freshened up mine a few times now.......i use the black over the silver, then i use VHT's clear high temp over that for a little shine...
Fred B
Old 10-01-2012, 07:58 PM
Grubby's Avatar
Patrickt - Are your pipes black ceramic coated?
Old 10-01-2012, 08:00 PM
Yes, but they are flat black -- not semi.
Old 10-03-2012, 07:28 AM
VHT FlameProof Ceramic paint work well on my ceramic coated side pipes.
B. Ewing
Old 10-03-2012, 09:54 AM
Cobra Make, Engine: 1968 GT350, FFR Daytona Coupe
Default High temp paint
My coupe has coated pipes in flat white. I touch then up all the time with either Rustoleum or VHT high temp paint.
The Vht clear high temp sounds like what you would need to achieve the gloss .
The Nut
Enough is enough. Too much is just right ( C.S )
Old 10-03-2012, 12:08 PM
In my experience the paint will stick fine if you clean the pipes, The finish will fade eventually but they will look better. I do mine once a year.
Old 10-03-2012, 01:09 PM
kgs365's Avatar
my understanding is this is what they do at ERA...first they ceramic coat then then spray em with high temp paint
Old 10-08-2012, 07:02 PM
Cobra Make, Engine: 351 Windsor
Try Aesthetic Finishers in Dayton, Ohio If you want them done right. Not very expensive either. They did mine a couple of years ago and they turned out perfect and matched my sidepipes spot on.
Old 10-09-2012, 10:53 AM
Default RE: Ceramic Coating Your Cobra Side pipes
Hello Grubby:
First, DROP the paint can….. Can you post pics of your pipes? By “silver colored” are you referring to traditional Bright Ceramic Coating? Also, what is the “wear” you are referring to? Once I see what you have I can offer some suggestions for you.
In general, Bright Ceramic Coating does NOT WEAR. Over time the aluminum skin may oxidize slightly but this can be prevented by occasional polishing with a NON abrasive polish. We use and recommend Flitz liquid polish but there are many other aluminum polishes.
I suspect you have some heat related issues but I can’t say for sure until I see pics.
Old 10-09-2012, 11:02 AM
Stones thrown by the tires chip coatings after less than 1 year. That's wear.
Chas.
Old 10-09-2012, 11:04 AM
Default RE: Ceramic Coating Cobra Side Pipes
John:
The success of VHT products depends on prep and cure cycles. It works for some but not most. If you want to change colors, which sounds like it may be advisable based on temps, I’d recommend High Temp Ceramic. The High Temp Ceramics are good for 2000F+ and generally more of a satin gloss level. The black is much smoother and more of a high sheen satin / semi gloss. We’ve run these in 4000hp + turbo applications with great success. Beyond black, there are about 10 other colors to choose from as well….
