Like Tree16Likes
  • 1 Post By Ron61
  • 1 Post By CSX 4133
  • 1 Post By SunDude
  • 1 Post By 55312
  • 1 Post By SunDude
  • 1 Post By Phx Mike
  • 1 Post By twobjshelbys
  • 2 Post By CSX3183
  • 1 Post By 1985 CCX
  • 2 Post By CSX3183
  • 1 Post By BAsque1
  • 1 Post By TimG427
  • 1 Post By FB54DM
  • 1 Post By tortuga
Old 03-31-2018, 09:14 PM
Cobra Make, Engine: Unique Motorcars, 428 big block
Default Keeping Drivers Floormat in Place
What are folks doing to keep the floor mat from sliding forward? Previous owner of my Cobra used Velcro which sticks well to the carpet but not to the mat. Has anyone installed a ferrule and hook like most new cars have? Tired of the mat bunching up under the pedals, not safe.
Old 04-01-2018, 04:11 AM
Ron61's Avatar
I did a couple of things and both worked well. I used the ferrule hook as you said but had to be careful to get the hole in the mat just right. In the other car I use two strips of double sided tape and it stuck to the mat and carpet very well and lasted for over a year before I had to change it. I also have rubber backed mats with small dimples on them that seem to hold them in place well as the dimples stick into the carper but not very far.
FB54DM likes this.
Ron 61
Ronnie Widener
View my Miscellaneous Gallery
Old 04-01-2018, 04:43 AM
Cobra Make, Engine: '65 Shelby Cobra, '66 Shelby GT350's
I've used the carpet socket type fasteners which work well for mats. Here's a link to a variety of fasteners for carpeting,etc.
FASTENERS - SNAPS, AUTOMOTIVE & MARINE - J & J Auto Fabrics, Inc.
FB54DM likes this.
Old 04-01-2018, 05:06 AM
Drive a screw with a large diameter body washer right through the floorboard. That will stop it !!!!
Old 04-01-2018, 05:37 AM
SunDude's Avatar
The Mat-Loc retention clips from GGBailey work like a charm. No drilling or major surgery required.
Buy 'em directly: https://shop.ggbailey.com/product/ma...ention-system/
FB54DM likes this.
Old 04-01-2018, 05:38 AM
55312's Avatar
Cobra Make, Engine: E-M 427 Top Oiler stroked to 482 by KC, Stage 2 heads, a Quikfuel and Voila, 640 hp
I bought these from G.G. Bailey. They've worked fine for years. One less thing to mess with.
Tim
FB54DM likes this.
At first, nothing happened. Then after a few seconds, nothing continued to happen.
Douglas Adams - Hitchhiker's guide to the Galaxy
Old 04-01-2018, 05:40 AM
55312's Avatar
YIKES......Great minds are all over this..............
Old 04-01-2018, 09:47 AM
Thanks guys! Tim and Sundude, your solution looks the best for me. Clicked on your link to order, just $8 but $11.97 to ship! Went to ebay, same clips, $7.99 free shipping. They are on the way here. Thanks again for the suggestion.
Old 04-01-2018, 11:25 AM
SunDude's Avatar
I've been using them in my Superformance since 2009, and they've worked flawlessly. Glad you found 'em with cheap shipping, too.
FB54DM likes this.
Old 04-01-2018, 01:45 PM
Phx Mike's Avatar
Cobra Make, Engine: Ex owner of a polished Kirkham 427 S/C. Now Cobra-less and driving a mid-engine German hot rod.
I did it the cheap-o way - put a couple of grommets in the back (ie seat side) of the floor mat and tie-wrapped them to the seat supports. That way I did not have to do anything to my carpet. Keeps them from sliding forward. The Mat Loc product looks like the way to go though.
FB54DM likes this.
Old 04-01-2018, 04:08 PM
twobjshelbys's Avatar
I've used these on almost every car that had mats without the little hook.
FB54DM likes this.
Tony
CSX4005LA
Old 04-01-2018, 04:50 PM
I did the simplest and easiest thing to do.
I just picked up the carpet, placed it in the trunk or behind the seat, and had the exposed fiberglass to rest my feet on.
When I stopped, you place the carpet back, and your car looks perfect.
No cost, no Gerry-rigging, no screws or other things pushed thru your floor, of course this works like magic if you have an original car, or if your mats also use snaps to secure them.
Dominik and FB54DM like this.
Old 04-01-2018, 06:28 PM
1985 CCX's Avatar
Easy fix!
Learned this from 3020.
Lift a dot just like on tonneau and soft top.
Put the pin through the floor and the lift a dot on mat.
Worked for me for 10 plus years.
Cost was about $5
FB54DM likes this.
Old 04-01-2018, 08:27 PM
I believe this is what I discussed just above your post, the snaps, the lift-a-dot snaps, that are original,,, to original cars,,, to attach the carpet, to the fiberglass floor, so you can remove them for easy cleaning, or to remove them to prevent excessive wear/ abuse if your racing your car, etc. etc.
1985 CCX and FB54DM like this.
Old 04-02-2018, 05:37 AM
BAsque1's Avatar
This is what I did, I took elevator wall mat studs and bolted them to the floor and eyelid grommets my carpets to fit the diameter of the studs and that did the trick since.Here are some pictures
FB54DM likes this.
Basque1
Old 04-02-2018, 07:40 AM
Cobra Make, Engine: Kirkham 599 Polished Bronze
I put a small hole in the floor mat and put a tie wrap through and connected it to the lever for seat adjustment. It has never moved again.
FB54DM likes this.
Old 04-02-2018, 11:02 AM
So many creative ideas, this is a great group.
1985 CCX likes this.
Old 04-02-2018, 06:01 PM
Murky781's Avatar
Cobra Make, Engine: ERA 781, 69' 428CJ, PPG BLACK. ERA 3005 Arctic White 331 SBF
I just take the floor mat and put it in the trunk when I drive. Only use it for shows or cruise nights. Easier to replace the basic carpet under my heel and cover the patch with the mat! yes I'm lazy, but I just want to drive the car not work on it. To each his own said the farmer as he kissed the pig on the nose. Enjoy the ride.
We make 3 bad decisions a day. Choose them wisely.
Old 04-03-2018, 04:24 AM
BAsque1's Avatar
Originally Posted by murky781 View Post
i just take the floor mat and put it in the trunk when i drive. Only use it for shows or cruise nights. Easier to replace the basic carpet under my heel and cover the patch with the mat! Yes i'm lazy, but i just want to drive the car not work on it. To each his own said the farmer as he kissed the pig on the nose. Enjoy the ride.
:lol::lol::lol::lol::lol:
Basque1
Old 04-08-2018, 07:42 AM
I sewed that white 3M Velcro to the back of the matts which sticks like glue to Superformance carpeting. I also have the stuff on the back of my cell phone, garage and gate remotes, and sunglasses case.
