Like Tree56Likes
Old 07-29-2019, 07:43 PM
hauss's Avatar
Default bronze gears
I Installed a bronze gear on my msd, because it was recommended to me by a friend, who races mustangs and has been around for a while. I have roller rockers and lifters, and it is a stroker motor. He said it was a lot less work to change a distributor gear, than a camshaft. Just wandering what others think because, I have read other post that say put a steal gear in the distributor.
Old 07-29-2019, 08:14 PM
HighPlainsDrifter's Avatar
Default Go steel
Hi,
bronze gears are for race engines that get torn down every month and changed out. They don't last in a street car and will fail and leave you stranded with metal shavings in your engine.
Perry
Dwight and TN Shelby Cobra like this.
F5 cobra Mark 4 roadster, **SOLD** Ruby Wine Red with pearl,
dual 2" roll bars, warmed up 302, Edelbrock AVS carb and heads, E Street aluminum Heads, Comp cam and roller rockers, AOD, 4.10 Eaton Posi, Power Baer/disc brakes, block hugger headers, 2 1/2" under car exhaust, F500 18" black spoke wheels.
Old 07-29-2019, 08:32 PM
Gaz64's Avatar
Get a steel gear to match, other wise you will need to inspect the bronze gear every few thousand miles. High volume oil pumps, and high oil pressure reduce the gear life.
Dwight likes this.
Old 07-29-2019, 10:56 PM
hauss's Avatar
Ok now for the real question if not sure what cam is made of what gear would be the safest to install.Keep in mind I do not mind working on my car if it will make it last.I already change oil every 3 months or 2000 miles. yes I know that is crazy but it helps me sleep at night. Also it does see 6200 rpms quite often.For some reason I just can not help it.
Old 07-30-2019, 01:28 AM
Sawdust's Avatar
If you want to be safe find out what your camshaft manufacturer recommends
Old 07-30-2019, 01:32 AM
Karl Bebout's Avatar
I went with a composit(aka,plastic) hear and have not had an issue. My hydraulic roller cam is not very radical, (Webers)
Thoughts appreciated. Am I looking for trouble?
Karlos
Old 07-30-2019, 02:37 AM
No bronze, no polymer, no plastic.
This is really easy....if it’s a cast iron core camshaft, use a cast iron gear. If it’s a steel core cam, use a steel gear.
The others will wear in short order.
Mike I, Dwight, bcrumpley and 3 others like this.
Old 07-30-2019, 03:21 AM
Gaz64's Avatar
Now reading your opening again, I see no mention of the camshaft material.
So your friend recommended a bronze gear WITHOUT knowing what the camshaft is made of?
Steel camshaft, steel or bronze gear. Steel is the best choice.
Cast iron camshaft flat tappet, cast distributor gear.
Old 07-30-2019, 05:34 AM
That's like the cobbler who always recommends wing tips. Of course, he also only sells wing tips....
Gaz64 and Hoodabest like this.
Old 07-30-2019, 09:50 AM
hauss's Avatar
He was trying to be safe and thought it would be a better to change a bronze gear than a worn camshaft gear. I am not saying this was the best way to go . I am saying not knowing the material the cam is what is the best way to go.Only because I have read on this site that bronze gears or not good .
Old 07-30-2019, 09:52 AM
You can tell by looking at the camshaft if it's iron or billet. If you have the cam card you can also tell by the serial number in most cases.
For instance, in Comp Cams lingo, a -9 or a -11 on the end of the cam part number indicates a steel core.
Old 07-30-2019, 11:44 AM
With a roller camshaft, I bet your cam is steel.
With each oil change, you can pull the distributor, and check the gear wear, and replace as necessary.
Old 07-30-2019, 03:01 PM
hauss's Avatar
I am going to stay with the bronze and check on it every 6 months The car is race car that just dosen"t get used everyday or on a track very often
Old 07-30-2019, 03:02 PM
Default oil pump
Hi,
your cam gear also turns the oil pump. So if you have a high volume pump and or 20/50 oil in the engine the stress is huge on the cam gear. I have seen a gear fail on start up when cold, the owner just revved the engine and that was it with thick oil.
Perry
Gaz64 likes this.
Old 07-30-2019, 04:09 PM
hauss's Avatar
I do not know if it is billet, or not so based on that I will keep the bronze gear. I also use 15/40 and let engine warm before I drive it.The oil arguement is one that can go on forever so I do not wish to go down that road let me just say I did my research and for me that was the best option. My oil pressure readings are always perfect no mater the temp even idle pressure stays right were it should.
Old 07-30-2019, 04:14 PM
eschaider's Avatar
To run bronze on anything but a pure race car is to unnecessarily tempt fate. Shoot for the happy ending by not using bronze. The name of the ending says it all ...
Ed
Old 07-30-2019, 04:36 PM
Gaz64's Avatar
I have a paperweight bronze gear that is "75%" worn with the gear tips worn to almost knife edges.
How long before the teeth would break off? Could have been the next engine start.
I don't use bronze any more, on anything.
Why do transmissions have steel gears against steel gears?
Old 07-30-2019, 05:05 PM
hauss - why would you put your engine at risk over a fifteen minute, $75 part, swap out?
Dwight and Gaz64 like this.
Old 07-30-2019, 05:56 PM
Dwight's Avatar
Smile
hauss let us know how much it cost to replace the bearings and flush all bronze filings out of the oil passages in the block. And if you have rubber hoses for a remote oil filter you will have to replace them and flush the cooler. Hope you can get all that crap out of your motor.
TN Shelby Cobra and Hoodabest like this.
Old 07-30-2019, 06:15 PM
eschaider's Avatar
I'd bet you could buy just the steel or cast iron gear for less than or equal to the price a five quart jug of oil at Wally World ...
Ed
