Old 12-09-2022, 11:35 AM
Default Solid mounted diff LCA support
Hi,
In UK.
I have a solid mounted diff and jag xjs suspension In board discs.
As I have gone turbo I need to support the LCA more.
Due to the design of the chassis, LCA bolt goes through chassis in a tube support, I can't get a rose joint etc inline with the LCA pivot to go to the LCA original radius mount.
My only option ? Is to do a watts link forward and aft of the LCA arm radius bush mount or top of the hub design.
Do both of these allow the movement up and down of the IRS?
Regards
Gav
Old 12-09-2022, 12:45 PM
Make brackets on the bottom of the lower control arm and the top of the hub carrier. Use these to control movement.
https://www.maximummotorsports.com/Q...1494-P971.aspx
Old 12-10-2022, 11:43 AM
Hi,
Thanks for reply but no idea what that means sorry?
Regards
Gav
Old 12-10-2022, 12:23 PM
CHANMADD's Avatar
Here is what I did. I have the 55" rear..2.88, lsd centre.
https://redirect.viglink.com/?format...26amp%3Bs%3D19
Old 12-10-2022, 12:24 PM
CHANMADD's Avatar
https://twitter.com/JohnMaddison2/st...VMf65kLzdrKPwA
Old 12-10-2022, 12:35 PM
Hi,
Thanks for response
Is that inline with the diff inner LCA? If not as from the picture does it bind through travel?
Regards
Gav
Old 12-10-2022, 04:19 PM
This uses a lower trailing arm, but a second torque damper could be used there too.
Old 12-11-2022, 09:00 AM
CHANMADD's Avatar
Originally Posted by GavCob View Post
Hi,
Thanks for response
Regards
Gav
hi there is absolutely no bind. But the way it is set up is if the vehicle tips say to the right the right side wheel will tow in and the left side rear wheel will tow slightly out or stay straight.
Old 12-14-2022, 05:33 AM
joyridin''s Avatar
This might work well for you also:
https://www.actoncustom.com/products...r-contemporary
