Old 02-16-2013, 07:22 AM
Cobra Make, Engine: 1966 427 CRII SB Ford stroked 408
Default SB oil capacity
Question: For years I have been hearing different numbers on how much oil goes in a SB ford motor with a external oil cooler. Correct me if I am wrong, a SB 351 with a standard oil pan holds 6 quarts of oil with a filter change, 5 without. Plus (or add) 1 quart with a external oil cooler up front like the ones most of us in Arizona run to cool the oil from the hot temps hear. I would like to clear this up. It make sense if 5 quarts stay in the pan 1 in the filter and one quart throughout the hoses and cooler itself oil changes should be 7 quarts. Racing pans are a different story, they tell you the pan holds a larger capacity of oil or not. Your input would be greatly appreciated.
Old 02-16-2013, 08:49 AM
Karl Bebout's Avatar
In my many years as a pump jockey/mek-a-nick, I always put 5 quarts of oil in a stock SBF, with the filter change. Ran across very few cars that required more, with stock oil pans and systems. I'm thinking that you're thinking wrong. The minimal amount of additional oil needed for the lines going to an external oil filter would probably be less than 4 oz. unless they are REAL long.
Karlos
Old 02-16-2013, 12:26 PM
Danr55's Avatar
Did everyone hear that? Karl admits to working on Fords. Never thought I'd see it.
I believe that Karl is correct. More interestingly, why the question?
Dan in Arizona
CCX3209
Old 02-16-2013, 03:01 PM
Ditto that, and from what the OP also assumed or read or heard -
... a SB 351 with a standard oil pan holds 6 quarts of oil with a filter change, 5 without ...
Nope, a standard oil filter does not take 1 QT of oil, more like 1/3rd QT.
Old 02-16-2013, 03:50 PM
Danr, of course I worked on Fords....They wre always breaking something so they made me a good living. There was always money to be made when it rained because they had a nasty tendenancy to miss or stall if they went through a big puddle of water. WD40 did wonders for them and made me a hero, many times.
AL427, The owners' manuals and Motor's Manuals almost always said to use the additional quart of oil, when changing the filter. Maybe they thought it was better to have more than enough rather than to trust the installer with measuring a few ounces. ??
Karlos
Old 02-16-2013, 09:52 PM
mikiec's Avatar
5 quarts with filter. Stock pan 302 SB Ford.
Old 02-16-2013, 10:40 PM
Rick Parker's Avatar
Most applications of the 351 also used a short filter.
Old 02-17-2013, 03:36 PM
Fitz's Avatar
Cobra Make, Engine: FFR Mk 3 408 530 - 585 T- mustang Dyno at B&R
Thought my 408 used 7? What do I know; it is day after birthday party
Fitz
fitzus1@gmail.com
Old 02-17-2013, 04:08 PM
Fitz--Finally hit the BIG 70?
Karlos
Old 02-17-2013, 04:47 PM
Fitz's Avatar
Feels like 78 instead of 73
Fitz
fitzus1@gmail.com
Old 02-17-2013, 06:32 PM
mikiec's Avatar
Fitz, you have one of Gordons pans on your car. They hold 8 quarts.
Old 02-17-2013, 06:48 PM
Happy Birthday Mr. Fitz
I thank you all for the reply's
Old 02-17-2013, 07:22 PM
Cobra Make, Engine: superformance 1022
Simple when I change the oil in my 347 I'll check the dipstick to see if it is filled correctly. The fellow I bought my SPF from said 8 qts with a filter change. I'll find out soon enough.
Tom
Old 02-17-2013, 07:23 PM
dave from mesa's Avatar
Cobra Make, Engine: FFR from Levy Racing 302 FI w/Edelbrock Performer heads
Happy B-Day, Fitz.
dave from mesa
Vietnam Vets may be eligible for medical care and disability compensation. Contact the VA if you have prostate cancer or type 2 diabetes. Finally got around to going to the VA.
Old 02-17-2013, 07:44 PM
Happy Birthday Fitz. You do look 78.
AZ Bob
Old 02-17-2013, 08:54 PM
Danr55's Avatar
Happy Birthday Mr. Fitz...
Dan in Arizona
CCX3209
Old 02-25-2013, 05:43 PM
Fitz's Avatar
Fitz
fitzus1@gmail.com
Old 02-25-2013, 05:47 PM
Fitz's Avatar
Roll Eyes (Sarcastic)
Fitz
fitzus1@gmail.com
Old 02-25-2013, 10:17 PM
vettestr's Avatar
Happy 78th Fitz.
Jeff Classic
Manufacturer of the Cobray-C3
www.cobrasnvettes.com
