Like Tree5Likes
Old 03-01-2015, 11:07 AM
Fitz's Avatar
Cobra Make, Engine: FFR Mk 3 408 530 - 585 T- mustang Dyno at B&R
Default Top five things that "break" on cobra replicar
THINK THIS MAY BE A GOOD START. WHAT SAY YOU? I HAVE MY OWN LIST OVER THE YEARS BUT WAS CURIOUS.
1. CARB NOT DIALED IN.
2. COOLING ISSUES.
3. SOFT TOP ASSEMBLE THINGY.
4. PROPER TIRES THAT GO FLAT.
5. LOSE BOLTS.
5a. CRAP BATTERY (it is Arizona)
JUST TRYING TO GET IT STARTED
Fitz
fitzus1@gmail.com
Old 03-01-2015, 11:23 AM
I've broken 2 transmissions.
Old 03-01-2015, 11:26 AM
Tommy's Avatar
Easy answer: LF brake, RF brake, LR brake, RR brake and parking brake.
Gaz64 and cycleguy55 like this.
Tommy
Previously owned EM Cobra
Old 03-01-2015, 11:27 AM
Nedsel's Avatar
Original Shelby Owner
Oh well, those are the brakes.
Ned Scudder
Old 03-01-2015, 11:28 AM
Buzz's Avatar
My list - combination of personal experience and what I've seen on the forum:
1. Overheating
2. Heat soak/vapor lock
3. Ammeter
4. Electrical/ground fault
5. Is it Real?
Tropical Buzz
Old 03-01-2015, 11:46 AM
twobjshelbys's Avatar
Any switch made by Lucas.
Jaydee likes this.
CSX4005LA
Old 03-01-2015, 01:00 PM
dallas_'s Avatar
I see what you did there.
Old 03-01-2015, 01:31 PM
Fitz's Avatar
So Far:
1 Transmission
1 Brakes
3 Overheating
1 Ammeter
1 Anything Lucas Switches
Fitz
fitzus1@gmail.com
Old 03-01-2015, 01:39 PM
Bernica's Avatar
Senior CC Premier Member
A 42 gallon Fuel Safe fuel cell is good for 4 years, then goes to hell.
Replacement cost is over $4k and that's just for the new bladder and internal foam, not to mention work to replace it all.
How do I know this?
Pulled the tank, pulled the cell, had it welded up with internal baffles, isolated pickup area etc.
If I race it, then I will deal with that.
Old 03-01-2015, 01:56 PM
MaSnaka's Avatar
Clutch master
Clutch pressure plate
Hydro throw out bearing (Clutch)
Collector flange gaskets, flange bolts coming loose
Intake manifold gasket leak, failure
All good now
Old 03-01-2015, 02:07 PM
Fitz's Avatar
So Far:
1 Transmission
1 Brakes
3 Overheating
1 Ammeter
1 Fuel Safe Cell
1 Clutch Related
Levy says the fuel safe cell lasts for 10 years. If I change mine I am going to regular tank.
Fitz
fitzus1@gmail.com
Old 03-01-2015, 02:40 PM
Cobra Make, Engine: FFR fat block tko 600 9"
fuel pumps, premature rear tire wear. :-)
Old 03-01-2015, 02:56 PM
Buzz's Avatar
I'll second these two:
Clutch master cylinder (probably heat related)
Exhaust header to side pipe leak (makes for some awesome blasts and pops on deceleration)
Tropical Buzz
Old 03-01-2015, 03:30 PM
DanEC's Avatar
So Far - the dirty (half) dozen:
1. alternator charge wire connection worked loose and fried the wire and alternator - probably nut pinched terminal insulator and vibrated loose
2. charging system not charging - not enough resistance to "excite" VR into charging action
3. black ceramic coating failed on exhaust - bad ceramic powder formula from California due to environmental rules change
4. lucas switch failed to switch (surprise, surprise)
5. heater shut off valve at engine had leak from porosity in metal.
6. brake master cylinder leaked fluid from start.
ERA 782 Running
Old 03-01-2015, 03:36 PM
Now I get it! Good one.
Old 03-01-2015, 04:23 PM
Buzz's Avatar
Yup - went over my head at first, but got it eventually. Good one!
Tropical Buzz
Old 03-01-2015, 04:49 PM
Danr55's Avatar
Motor! Need I say more?
Dan in Arizona
CCX3209
Old 03-01-2015, 05:04 PM
ERA 778's Avatar
Cobra Make, Engine: ERA #778 427SC Keith Craft FE 428 stroker
Can't believe FE oil leaks are not on here yet, but cooling system and getting carb dialed in are also in my top three. Smith's speedometer went south as well.
Old 03-01-2015, 05:11 PM
Cobra Make, Engine: B&B 306/FORD
MSDeeeeeeeeeeee!!!!!!!!!
Old 03-01-2015, 05:59 PM
Dwight's Avatar
Smile
two alternators
two starters
four pair of rear tires
Dwight
