Old 06-11-2011, 09:45 PM
Zedn's Avatar
Default LS sump measurement?
Gday,
I am after measurements for sumps from LS engines. If you have an LS engine in an easy to reach spot, would you mind throwing a tape on it for me to check the overall outside depth (bottom of the drain plug casting)?
I have an LS3 which is about 185mm deep. I think the LS1 sumps might be around 125mm, but im not sure. Looking for measurements for LS1, LS2, L76 and L98.
I have my motor sitting in there at the moment, but it will be a very tight fit for height and i would like more clearance under the car.
Cheers.
Liam
Old 06-11-2011, 10:26 PM
Krait's Avatar
Liam,
Have a look at this older post, might give you the answers.
Geoff
Old 06-11-2011, 11:34 PM
Zedn's Avatar
That answers my question, thanks. I will price up the corvette LS2 sump, but it looks like it will be around the cost of the moroso so i might go with the moroso if it has more volume.
Sambo, where did you and Stiffy order the sumps on that thread from?
Old 06-12-2011, 12:16 AM
Krait's Avatar
Liam,
I think we all bought them from Speed Inc. Email Fraser, fraseratspeedincdotcom, for a price.
You may not need the windage tray. They are the same as the production item, at least for an LS2. Ensure you get the dip stick and pickup though as they are very different.
Geoff
Old 06-12-2011, 01:15 AM
Zedn's Avatar
This looks like a good price. US$347 for the whole lot.
C6 Vette Rear Sump Oil Pan Kit SSPK - Crate Engine Depot
For reference, as i am doing the engine mounts right now, should i go off the bottom of the T56 bellhousing as the lowest point or does the short filter sit slightly lower?
Old 06-12-2011, 02:01 AM
Krait's Avatar
Looks like a good deal.
The short filter sits about level with the sump.
Geoff
Old 06-12-2011, 05:30 AM
Zedn's Avatar
Thanks for the pic. Its a huge difference in depth from the LS3.
