Like Tree197Likes
Old 01-25-2013, 12:59 PM
DaveW's Avatar
Default Dave's CR3514 Progress
Hey Folks,
Still plodding away in the shed when i'm home, so i thought i'd post some progress pics of the engine.
A before and after shot,
I've posted some more detailed pics and descriptions on my blog.
I'm working on the gearbox (TR6060) at the moment, custom remote bleeder etc, and a tidy up, i'll post some details shortly on my remote bleeder system.
Dave
Before
After
I intend to replace the manifold with a Kinsler X-Ram when the time is right, although with Dollar as it is at the moment, sooner than later maybe.
some pics i found on the web
Aussie Mike, Mando, Dimis and 5 others like this.
Old 01-25-2013, 01:11 PM
Mando's Avatar
Dave, that looks gorgeous. It looks like you've shifted the engine mounts forward, I didn't know that was possible and I've never seen the coils mounted in that position, it looks fantastic, great work!
Regards.
Mando
Old 01-25-2013, 02:08 PM
gjkrv8's Avatar
Looking great Dave. Luv the Rocker covers and coil relocation option, cheers Gregg
Old 01-27-2013, 05:55 AM
Aussie Mike's Avatar
Looking really good Dave. I like the detail you've put into the alternator.
I had a similar idea with the coils. I originally had them in the foot boxes but I've found that I occasionally catch my foot on them when going for the clutch. I looked at mounting them on the block where you have yours but the way my headers run they wouldn't fit. It's also pretty tight around the starter motor.
In the end I made up some brackets to mount them to the chassis rails just behind the engine mount. Plenty of clearance around them.
I'm mocking up the plug leads at the moment. These are MSD leads with right angle plug boots from a Gen 1 Chev. Just got the get them re-terminated with the LS1 coil connections.
Keep the updates comming. We love the build threads.
Mando and leroy17 like this.
Mike Murphy
Melbourne Australia
Old 01-27-2013, 05:16 PM
DaveW's Avatar
Mike,
I was trolling your pics yesterday, to see how you had run your leads in relation to the headers. I saw the leads going through the side wall. The above shots are perfect.
I may still have to move the mounts on to a chassis rail as well, the left hand side looks like i can make the header clear, on the right i'm going to measure up an indexable MSD starter to see if i can get enough clearance.
Also loved your new PS pump location and bracket.
Did you get the exhaust manifold to head plates locally to build your exhaust ?
Regards
Dave
Old 01-27-2013, 05:38 PM
Zedn's Avatar
I plan to make up billet specialities style valve covers that cover the coils in the stock location. I would be a bit concerned about the heat from the headers in that location. You probably should make a heat shield for them if you can fit it.
Old 01-27-2013, 06:06 PM
Gav's Avatar
Gav Gav is offline
The header flange plates are available commercially.
Any exhaust joint should be able to order them in.
Powered by Cu
Old 01-27-2013, 06:12 PM
Originally Posted by DaveW View Post
Mike,
Regards
Dave
I got the header plates from Difilippo exhaust in Melton. Daren is good to deal with.
I had already built my headers before deciding to remote mount the coils. I probably could have made clearance if I'd built them after.
I liked how I had the leads running originally through the footnboxes but after driving it they could be a bit of a nuisance. It also made getting at the steering shaft uni a bit of a pain. I figure with them mounted down low I will be able to clean up the foot boxes. This setup is better for servicing things. These days I like the idea of simplifying things and making things easy to get at and fix/replace.
Mike Murphy
Melbourne Australia
Old 01-28-2013, 03:52 PM
MSD make a universal lead kit for LSx motors. It comes with a range of different boots and the LS1 coil boots and a crimp tool. I just ordered one from Summit as it will save me cutting up these good leads.
The price is better than I paid for the last set of custom leads I had made and with them I had to supply the old leads so they could reuse the coil boots.
Red Super Conductor Gen III LS-1/6 V8, Universal - 32079
MSD 8.5mm Super Conductor Spark Plug Wire Sets 32079 - SummitRacing.com
Mike Murphy
Melbourne Australia
Old 01-28-2013, 04:12 PM
There's a used one of those MSD indexable starters on ebay at the moment MSD APS 3hp mini high torque adjustable ls1 - ls7 starter motor MSD 5096 | eBay
Mike Murphy
Melbourne Australia
Old 04-21-2013, 07:58 PM
DaveW's Avatar
Howdy all,
A bit more progress, feel like this ones a milestone,
Engine and trans mounted in the chassis.
The original inlet manifold is sitting on top to stop wasp from nesting in the inlets, i only seem to have his problem around engines, ...whipper snipper, mower, bikes etc etc, they must love hydrocarbons or something.
I'm in discussions with Kinsler for a cross ram at the moment, see how we go,
The trans has a Core Hurst TR6060 Shifter, Hurst components in a custom mount, nice piece of work.
Also fitted clutch speed bleeder, home made 8x1.25mm slave fitting to -3AN, then flex brake line to 10mm concave fitting and 10mm Russel speed bleeder nipple.
Brakequip made up the hose, and the Speed bleeder came from Russel components off the web.
I bought an MSD indexable starter motor MSD5096, nice unit, but they can only index around 15deg either way from the center vertical position, not far enough to clear my coils, i then designed a custom mount bracket to kick it over to 90deg, but have since found a RobbMc starter perfect for my use that can be infinetly adjusted, MSD going cheap to any interested persons, not even used to go to church and in original box.
A bit of plumbing, fuel, tank and radiator on the go now.
Dave
Dimis and d488y2 like this.
Old 04-21-2013, 08:39 PM
Dimis's Avatar
...and the bar is lifted again
Old 04-21-2013, 08:51 PM
Modena's Avatar
Dave the pics are not showing up, and without pics, it didn't happen
Ben in AU
Old 04-21-2013, 08:58 PM
boxhead's Avatar
No pics for me neither :-(
Cruising in 5th
Old 04-21-2013, 09:17 PM
Modena's Avatar
all pics except the second one are now showing up.
Ben in AU
Old 04-22-2013, 12:04 AM
DaveW's Avatar
The pics are showing up for me, but this is the first time i've used photobucket.
I cant upload pics anymore to clubcobra, no buttons appear to select photos or upload.
i just pasted the photobucket link
any help on what should or shouldn't be in the link gratefully appreciated,
add.
i amended the links to just the info between the bracketed IMG quotes, let me know either way if this is working for all.
Dave
Old 04-22-2013, 12:38 AM
boxhead's Avatar
You need to post the photobucket IMG link
Cruising in 5th
Old 04-22-2013, 03:38 AM
DaveW's Avatar
Some more pics, still trying to get the hang of the photobucket img address thing
This is whats under the shifter cover on a TR6060 box
The Core Hurst Shifter
Old 04-22-2013, 05:03 PM
boxhead's Avatar
It is good that the new boxes already have a shifter location in there, I did the MM mod.
Cruising in 5th
Old 02-20-2014, 07:01 PM
DaveW's Avatar
Gee its been a long time since i posted some progress pics,
Saw Mando's comment on another post about the number of builds but the lack of progress posts on here, and i'm one of the guilty, so heres some progress pics.
Firstly,
Mounted the engine and gearbox in the chassis and since then some dress up as i've tinkered along making brackets for Oil Cooler, Canister, Brake and Fuel lines etc.
At the moment, i'm playing with the manifold and dual quad EFI, trying to get a bit of a modern ol' school look.
Also mounted the brake and master cylinders so i could make up the clutch lines and playing around with a header modelling kit to see if i can get the cats inside the bay instead of underneath as there isnt much exhaust or tube area.
The canister is from a VE commodore.
CNC'd the battery mount to suit the Optima Battery.
Made up some shims for the steering rack mount.
This is the Oil cooler mounted and tubes / hoses.
Dave
Aussie Mike, guye, Chris L and 7 others like this.
