Like Tree493Likes
  #281 (permalink)
Old 02-01-2016, 04:34 AM
750hp's Avatar
Great video!
"Has it got good oil pressure?"
"Nup....oh yeah"
Love it!
guye likes this.
Craig
  #282 (permalink)
Old 02-01-2016, 04:43 AM
guye's Avatar
There's so many dials and gauges and stuff, Craig! I didn't know where to look!
Donunder and Laner like this.
Guy
  #283 (permalink)
Old 02-01-2016, 04:47 AM
guye's Avatar
All I need to fix now is the tacho and speedo. (And the stereo.)
Apart from that, I can't believe I sorted out all the issues in one afternoon.
Oh, except my cheap-arsed review mirror won't stay stuck on! Have to go to Autobarn for that proper glue I suppose.
And now it's off to engineering we go!
Guy
  #284 (permalink)
Old 02-01-2016, 04:56 AM
leroy17's Avatar
That's awesome,well done, it's been great to follow this and I look forward to the following updates with rego and future things to finish off and enjoying building a car.
Never skimp on pics, it never gets old.
  #285 (permalink)
Old 02-01-2016, 05:03 AM
guye's Avatar
Thanks Leroy. Intention was always to post more pics, but sometimes when you're "up to your neck in crocodiles, it's difficult to remember you're meant to be draining the swamp!"
Will post more detailed close ups over the coming weeks as I go through the regos process.
Guy
  #286 (permalink)
Old 02-01-2016, 05:19 AM
albanycobra's Avatar
Well done....sounds great and starts sweet.
  #287 (permalink)
Old 02-01-2016, 12:52 PM
gjkrv8's Avatar
Well done Guy. You must be stoked. Great work. I don't know if I can cope with two Cobras in the work car park. :-) Cheers Gregg
  #288 (permalink)
Old 02-01-2016, 02:19 PM
Good on Ya' Guy...............Muz
  #289 (permalink)
Old 02-01-2016, 02:34 PM
Donunder's Avatar
Guye that's been one of my "milestones" in the various build threads -- waiting for your first start-up. It went beautifully.
Congratulations!
Now, good luck with the bureaucrats...
albanycobra likes this.
Don.
  #290 (permalink)
Old 02-01-2016, 04:45 PM
stephen low's Avatar
Good work Guy, always a special moment when a first start happens!
Keep at it.
slowy
  #291 (permalink)
Old 02-01-2016, 05:45 PM
Cobra Make, Engine: Pace 427SC. LSA Supercharged with 6sp TR-6060 trans.
While it sticks to the glass ok, I don't know if it's all the windscreen-mounted mirrors but my mirror jiggles all over the place so badly that it's impossible to see out of when driving. In any event, I have a chrome post mirror from Finishline that I'll be fitting after I paint the car.
Fantastic result on getting the car started Guy! Sounds great!
www.paintwerks.com.au
  #292 (permalink)
Old 02-01-2016, 07:57 PM
DaveW's Avatar
Well done Guye, great stuff, a big milestone and it sounds great.
Hope mine starts as swiftly.
cheers
Dave
  #293 (permalink)
Old 02-07-2016, 02:41 PM
guye's Avatar
Ok, engineering tick, except for noise test. The engineers tacho was broken, so I need to go back for that this week.
Hopefully the emissions goes as smoothly. Waiting, waiting....
Guy
  #294 (permalink)
Old 02-07-2016, 02:48 PM
guye's Avatar
Oh, and I'm having the devil of a time trying to get my speedo working.
It is electronic. (Speedhut) It only has one wire for the speed.
I do not have a vss output from my ECU. So I am taking the feed directly from my vss sensor on my tremec tr6060 gearbox. I know this works, because it is currently wired into my ECU and my scanner reports the speed ok.
I have tried connecting the speedo wire to both sensor wires in turn, with no result.
I then tapped into the sensor wires directly at the source and ran a second wire just in case I was getting too much loss. I only tapped into what I'm sure in the 'high' wire (white with purple stripe). No luck.
I then also tried to insert a booster voltage from a 12v source through a 4.7kohm resister. Still nothing.
I haven't tried insert the lift voltage into the 'low' wire in case this damages the ECU cause they are connected in parallele after all.
However today I notice that my odb2 scanner has stopped reporting speed now too!
Any (helpful) advice gratefully accepted....
PS: Don't mess with me, I'm close to the edge! So close....
Guy
  #295 (permalink)
Old 02-07-2016, 03:06 PM
gjkrv8's Avatar
Hey Guy, I saw another thread from Jethro in Perth who has a speed hut gauge and his problems was:
"So a trap for the younger players. Turns out it was always working. Thing is for these gauges (Speedhut) the speedos read zero until you do a calibration. Then they start reading (showing) something.'
Did you do this?
cheers
Gregg
  #296 (permalink)
Old 02-07-2016, 03:12 PM
guye's Avatar
Thanks Gregg,
Yes. I'm not a young player, but thanks for the boost
When calibrating it it waits 5 seconds and says 'No Signal'.
Guy
  #297 (permalink)
Old 02-07-2016, 03:18 PM
guye's Avatar
Oh, and here's a first. Two Pace Cobras together at a working bee yesterday in Victoria. Simon (car on the right and he is in the cobra den) and myself.
Refitting better exhausts gaskets.
mate, Laner and Auswallaby like this.
Guy
  #298 (permalink)
Old 02-07-2016, 03:24 PM
snakesaway's Avatar
Cobra Make, Engine: Evans and Wooley, 302 Windsor, Supra turbo 5sp
Hi Guy,
I have been meaning to ask you were you got your exhaust gaskets made need some to go between the extractors and the side pipes. The ones i made are ok one is starting to leak already.
Andrew
  #299 (permalink)
Old 02-07-2016, 04:03 PM
guye's Avatar
Homemade Andrew.
Wait until I'm sure they work before you ask my advice! But also I'm expecting the dudes that made my exhaust to finish a jig so he can stamp some gaskets customised for the exhaust setup.
Guy
  #300 (permalink)
Old 02-07-2016, 04:09 PM
snakesaway's Avatar
Dam I was hoping they weren't homemade. Min are so we are in the same boat then. I look forward to you results.
