February 2026
Like Tree133Likes
  #41 (permalink)
Old 11-13-2014, 10:09 PM
400TT's Avatar
Don't want to be a wet sock but is it engineered and passed in QLD only ? the rules are strictly different in NSW so I hope you can make them meet there too !
Despite that negative crap....Good Job on getting it regoed !
No major difference these days between states, we run under a National code, which was driven by NSW. There is still a difference in interpretation by each engineer but usually only on minor items. And also differences where testing facilities don't exist. e.g. in NSW you can use any engine as long as it passes IM240 (ADR 37/01) emissions test, QLD it has to be a verified production engine that meets or exceeds ADR 37/01 emissions without any modifications that degrade it's emissions.
And QLD has now adopted the full National Code for the process and things are much easier, much simpler registration now for us that we now use the same system as NSW.
Also keep in mind that even if a kit brand has been registered here in the past, you may not be able to register that kit brand under the new code.
And personally I would like to see more safety requirements in the areas of occupant safety, brake performance etc. For example, it is why we have 8mm structural side wall on our chassis to better protect the occupants lower body and legs from side impact.
Wazza, Russell9318 and Zacson like this.
www.absolutepace.com
  #42 (permalink)
Old 11-13-2014, 10:20 PM
400TT's Avatar
Originally Posted by TheDoc View Post
Could you post some pics of your engine bay close out panels if you ever get a chance?
Doc, I will drop you an email with some additional photos of them from our manual resource library. We also have a 3D CAD visualisation drawing of them on the chassis. We have the manual itself and then all the full resolution versions of photos from the manual and other additional images and files. Due to the size of it, it will need to be burnt onto DVD or onto USB stick. Will do you one next time you drop in.
Wazza, Towmaster and Russell9318 like this.
  #43 (permalink)
Old 11-13-2014, 10:37 PM
400TT's Avatar
Originally Posted by Hail427 View Post
just a last minute question how much does it take to fill the tank?
The standard PACE 427 tank is just over 68LT.
The optional long range tank capacity is 92LT.
And we can do even more capacity if required.
  #44 (permalink)
Old 11-13-2014, 11:55 PM
400TT's Avatar
Originally Posted by Modena View Post
I think maybe it looks 1/2" TOO low.
The nice thing with our design is you can effectively run any ride height you like and run the wheel in any position in and out you like. Or adjust it front to rear in the wheel arch.
You can also run any amount of turns lock to lock on the steering e.g. 2 1/4, 3 etc. Well we can actually can do less than 2 1/4 for track cars.
We have a very tight turning circle, but if you want to run wide tyres on the front e.g. 275 etc we can adjust that so the tyres do not rub on full lock. You can run 345 etc on the rear if you like.
Same with caster, different bolt on brackets give different casters so you can run 5 degree or run 3 degree etc.
Camber is fully adjustable.
And we are happy to make custom bolt on mounting brackets to adjust any aspect of suspension geometry - anti-dive, anti-squat etc. Even the steering rack height can be adjusted.
It is all very flexible.
Towmaster, jcraigau and Tonus72 like this.
  #45 (permalink)
Old 11-14-2014, 06:05 AM
guye's Avatar
Originally Posted by 400TT View Post
... Manual .... Pics... CAD. ...Due to the size of it, it will need to be burnt onto DVD or onto USB stick.
There's an idea. A Pace 4.27GB USB stick containing the manual delivered with every kit. How 'bout that Craig?
mate and messy like this.
Guy
  #46 (permalink)
Old 11-15-2014, 03:38 AM
750hp's Avatar
Brad, I just realised something. This photo might be proof that the AP cars are in the very rare category of Cobras that have hand brakes that actually work!
My car would be wrapped around something at the bottom of the hill if I relied on my handbrake alone...
guye, Russell9318, Cobra01 and 1 others like this.
Craig
  #47 (permalink)
Old 11-15-2014, 06:06 AM
Donunder's Avatar
I was struck by this photograph too.
I remember pulling up in a similar position once and my passenger looked at me inquiringly. I asked if anything was wrong and she said no, it's fine, I can walk to the footpath from here.
guye and Cobra01 like this.
Don.
  #48 (permalink)
Old 11-16-2014, 01:07 AM
Cobra Make, Engine: Absolute Pace 427 SC
not to take anything away as the car looks awesome, but I think maybe it looks 1/2" TOO low. And lose those headrests - my gawd they look horrid!
Hi Ben
I have just raised the front of the Cobra and it took me all of 15 minutes to do the job.
It took me longer to get the jack under the chassis than it took to raise the front of the car.
But the headrests stay.
Brad
P.S. I heard that you ordered a Pace 427 SC is that true ??
There is nothing better than a cold beer
  #49 (permalink)
Old 11-16-2014, 01:44 AM
Modena's Avatar
Why would I order a Pace? I have been building a Classic Revival for 3 years and it will be driving in a month or three, you must be thinking of someone else.
Ben in AU
  #50 (permalink)
Old 11-16-2014, 01:53 AM
My apologies it must be another Ben
Good luck with your build
Brad
  #51 (permalink)
Old 11-16-2014, 01:59 AM
Modena's Avatar
I did show my woman some pictures of a GT40 today, after I told her its 40" tall and she said "what, off the ground?" "no dear, the entire car is 40" tall", then showed per pics, "oh it looks like a Corvette"
*sigh*
I will probably order a Pace one day, but not a Cobra
Cobra01 likes this.
Ben in AU
  #52 (permalink)
Old 11-16-2014, 02:20 AM
*sigh*
Its a sad fact of life that if you were talking about hand bags and shoes to your wife then you would have her undivided attention
Brad
  #53 (permalink)
Old 11-21-2014, 12:12 AM
1 TUF AC's Avatar
Cobra Make, Engine: Harrison, LS1 stack injection
so true about the hand brakes on ac cobra's. When i was shopping for a cobra hardly any of them worked. And the first one I found that did work properly I ended up buying. might end up being a collector's item one-day lol. The rear end of a absolute pace looks awesome enjoy.
Cobra01 likes this.
  #54 (permalink)
Old 11-21-2014, 06:18 PM
Tengu's Avatar
Cobra Make, Engine: Contemporary Classic CCX3021 Keith Craft 428fe
Congrats Brad, looks great.
"How many people here have telekinetic powers?...raise my hand"
  #55 (permalink)
Old 11-21-2014, 10:17 PM
guye's Avatar
Awesome Ben! She knows a Corvette is a car! And a sports car at that! I'd say you're on a winner there!
Guy
  #56 (permalink)
Old 11-22-2014, 01:30 AM
Brad
Brad,
You were thinking of me.
Ben
  #57 (permalink)
Old 11-22-2014, 11:28 AM
Thats the trouble when you get old.
You forget names and other things
Brad
  #58 (permalink)
Old 11-22-2014, 02:14 PM
Tonus72's Avatar
Cobra Make, Engine: ?????
Hi Brad
I hope you don't mind me pinching your photo.
A mate was showing off some black and white photo skills on facebook. I doctored up this to play along...
The road to hell is paved with good intentions
  #59 (permalink)
Old 11-22-2014, 02:57 PM
Hi Tony,
I don't mind at all but it looks a bit like a dark grey doesn't it.
It might be a new colour who knows.
I have done 1500 kms in the car total with 1000 kms since it has been registered.
I try and drive it every day and so far I have only missed one day.
Brad
d488y2, Laner and itempany like this.
  #60 (permalink)
Old 11-22-2014, 03:58 PM
itempany's Avatar
Cobra Make, Engine: Drb, 302 Comp cam, Cobra Nationals 2001 and 2002
Sounds like me. When I purchased my 2000 Drb last year, it had 4500 km on it. Now it is closer to 9500km. If its not raining why not enjoy the car. I have been caught out a couple times with rain and it sure makes for a hair raising experience!
Ian
Cobra01 and 1 TUF AC like this.
